993 Forum 1995-1998
Got my car back! Re-gearing done!
Old 09-23-2004, 04:04 PM
993RS
993RS's Avatar
One thing is for sure: It cost the heck of a lot less than a 3.8L conversion and brings much, much more for my particular needs. (I would reckon subjectively at least 3 times more)
Old 09-23-2004, 04:07 PM
Toga
Toga's Avatar
It sounds very good!
Do you intend to publish some ref. timings?
I feel a need from some fans to travel to Lugano to see the "beast"
Have fun Phil!
Old 09-23-2004, 04:22 PM
993RS
993RS's Avatar
Have fun Phil!
Actually, no. The only thing I came close to doing is a simulation on the cartestsoftware package, which has been mentioned on this thread, it really seems to offer some useful results. I did do a comparision of acceleration times between a stock C4S and mine with just the shorter gear ratios, and came up with 5.5 seconds versus 5.0 seconds. But these are just fun games IMHO (which admittedly I like doing), the real test is when you actually sit in the car and drive it.
Old 09-23-2004, 04:51 PM
914und993
914und993's Avatar
How far off was the camshaft timing? Did you have reason to believe it was off before checking it?
Chip
Old 09-23-2004, 05:20 PM
akolodesh
akolodesh's Avatar
I bet its an amazing drive. What would you say is the "feel" difference between the g50/21 euro gearing and your custom Rennsport gearing? If I remember correctly you had kept 5th gear and moved it to 6th in your new setup?
When you write 50hp difference, in what part of the rpm range do you really feel that "50 hp" difference?
Thanks alot.
Old 09-23-2004, 05:37 PM
Benton
Benton's Avatar
Man, if I only had extra money...
How do you like the steel synchros?
Old 09-23-2004, 05:49 PM
akolodesh
akolodesh's Avatar
Steel Synchros? You went with Steel Synchros? Not on the first two gears did you? I understand that if you grind steel synchros they are done.
Old 09-23-2004, 06:47 PM
flatair
flatair's Avatar
Awesome news! I just knew it would be a beast!
Here's more cartest 'in theory' info from another thread, compares VRAM, non VRAM, 993RS's setup, E46 M3 as a reference, etc etc. Interesting numbers. BTW 993RS if you'd like the dat file with the cars i worked up, just let me know and I'll email it to ya.
Old 09-23-2004, 08:20 PM
KRA993tt
KRA993tt's Avatar
What's this about cam timing? What was the fix or change?
Old 09-23-2004, 11:00 PM
993RS
993RS's Avatar
Chip
Yes, the throttle response was sluggish. The ideal valve opening is 1 mm. The measurement showed: left cylinder bank 0.84 mm and right cylinder bank: 0.92 mm.
Old 09-23-2004, 11:06 PM
993RS
993RS's Avatar
Thanks alot.
The feel difference was twice as good as when I did the G50/21 conversion on my last car. Yes, my old 5th gear is now my new 6th gear.
I really feel what seems like 50 hp more through the whole rev range. The car was a bit slow in 2nd gear in the lower rev range up to about 3500 revs. Now it starts pulling from the very start. Plenty of low end torque. Above 4000 revs though, it really kicks in...
I really don't recognize the car anymore. I find it just as responsive and fast as a 997 Carrera S...
Old 09-23-2004, 11:07 PM
Benton
Benton's Avatar
Phil,
What about the synchros? What gears are they in, how do they feel, and how do you like them?
993RS
993RS's Avatar
I went with steel synchros on 2nd through 6th, as recommended by Steve W.
Old 09-23-2004, 11:12 PM
993RS
993RS's Avatar
Flatair,
Yes, by all means, thanks!
Old 09-23-2004, 11:13 PM
993RS
993RS's Avatar
They measure the valve opening at the dead point by installing a pair of mechanical valve lifters for the measurement. Ideal opening is 1 mm, as I mentioned above.
Quick Reply: Got my car back! Re-gearing done!
