There's a new FOB on the block
#31
Call around to multiple dealers if you have them in your area. Stevens Creek (San Jose) told me he has to program a fob with the computer 😂
not every shop is going to know what to do.
#32
Basic Sponsor
Loren
Systems Consulting - Automotive Electronics
Specializing in Porsche cars
http://www.systemsc.com/
Loren
#33
^^^ That.
Years ago I had the same problem. Like you, I suspected the PIN I was using was wrong, so naively just called the Porsche dealer to get it from the VIN. They wouldn't give it to me without me coming in with proof of ownership. That's a bit of a hike for me so I asked if they could at least confirm that what I was using was correct. They agreed to do that over the phone (and it was correct), so give that a try first. Different dealers may have different policies so shop around. If all else fails, send me a fob and I'll make a backup you can use that doesn't need to be programmed. See here
#34
Basic Sponsor
Correct. The F1-EZ is designed for those who can't program fobs in-car and don't want to go through the hassle and cost of sending the immobilizer out to be programmed. All you need to do is send a fob currently paired to your car and we'll make a copy you can use without having to program it - much easier and less costly than sending the immobilizer out. Turn-around time is typically one day. Read more about it here.
M1TC (07-22-2024)
#35
Hi Jay, all, just checking in again to confirm if any longer range with these? Will probably order in the next week or two anyway but would love to know. Thank you! Matt
#36
IIRC, it is the capacitors that need to be replaced in the immobilizer box that gives you the increased range. Found the link : https://rennlist.com/forums/993-foru...is-easy-3.html
#37
Basic Sponsor
front: 57'
driver side: 64'
pass side: 54'
rear: 11'
These ranges are greater than both of my OEM fobs. Will you get the same results? Probably not. Could be more. Could be less. Depends on your immobilizer. I will point out that if you're currently getting ~5 ft or less range with your OEM fob (and it has a fresh battery and clean contacts), the immobilizer is probably the limiting factor, not the fob. If that's the case, consider doing the capacitor refresh - the improvement can be dramatic. The above ranges were measured with the fob held out elbow length from the body. Holding it at the hip yielded ranges 7 ft greater, on average. Bottom line: range depends on many factors, so YMWV. Hope that helps.
M1TC (Yesterday)
#38
Hi Jay,
I've been using one of your updated fobs from a few years back (flawlessly I might add), and was wondering how/if this new version differs from the one I have? Thank you.
#39
Got it thanks! Yep, was looking for a comparison between original and this fob. Whenever I can actually get my act together and order one of these I will try to do a test and update. Thank you!
#40
I think im going to just send you guys one of my working fobs and have you all clone it for simplicity.
#41
Basic Sponsor
Good choice! Order the F1 EZ on the website and you'll get instructions on where to mail your fob. I can usually turn it around same day.
#42
#43
Basic Sponsor
PM sent
