Where Are All of The Alternators?
I've called about 20 or more companies for their stock alternators and no body has them. I even called the stealerships and they don't have them in stock either. They explained that Porsche has been sending out some of their electonics to Ukrain for manufacturing. Well that explains everything. Thanks alot Putin!!!! Does anyone have any suggestions?
Ken
Ken
M. Schneider (08-01-2022)
The following 2 users liked this post by Porsche-ah:
993Porsche (06-23-2022),
M. Schneider (06-22-2022)
Have the original rebuilt. The Bosch reman ones are trash. Cheaper to rebuild and much higher quality. It's not like the rotor or stator wear out.
The following 4 users liked this post by 71-3.0-911:
Alternator rebuilder .. https://davilco.com
www.davilco.com The firm Daviilco Electric comes highly recommended by a fellow lifelong hobbyist; A neighbor. The company is in Baton Rouge, LA
The following 3 users liked this post by M. Schneider:
PM sent.
Thanks,
Ken
Originally Posted by 993Porsche
Yep great idea, but the center shaft that holds the hex/spline tool striped. Can the repair shops repair that or do I have to take it to a machine shop?
Thanks,
Ken
Thanks,
Ken
Seared
Short of welding the head of an allen bolt to the end (and then turning down the weld diameter), there really isn't anything a machine shop can do to repair the stripped splines.
Also, your bearings have play.
In the meantime, this stuff is just collecting dust...
Andreas
The following 2 users liked this post by AOW162435:
Matthew So (08-01-2022)
Honestly, just have a machine shop weld a hex head to the end of the shaft and make sure the threads stay clean. I see an Allen head not much better than the 12 point for longevity.
Perfect time to install a Clewett and be done with this whole thing.
Andy
The following 2 users liked this post by pp000830:
M. Schneider (08-01-2022),
I bought a simple rebuild kit and did it all myself. New bearings, new brushes, copper races, cups, and voltage regulator.
The following 2 users liked this post by 71-3.0-911:
If the shaft end is stripped a screw extractor bit can probably hold it while removing the pulley, also you may have used the improper star tool and a different one will hold it just fine. If you just want to hold it to tighten the pulley nut I seem to recall someone describing putting a screwdriver through the fan into the alternator to bind it while loosening/tightening the nut.
Andy
Andy
