A Plug-and-Play, DIY-Installable 993 Immobilizer Defeat
#541
993 socket for cigarette lighter is always ON, make sure nothing is plugged into it; also, if you activate the alarm (some people will even do that while the car is in home closed garage) that could drain the battery as well.
Please note that if you end up jump start the battery, the battery life gets shorten by at least 20%.
#542
Basic Sponsor
Question, I have made this IMMO mod with my 97 turbo, every since it seems as if my battery is draining very quickly, replacing car battery this week but was wondering if its due to the IMMO mod is pulling power or if the battery just went south. The battery is an interstate was only 3 yrs old.
Avoid guessing whether you have an excessive battery drain or not! Typically, the 993 battery drain is less than 60ma (.060 amps).
Loren
Systems Consulting - Automotive Electronics
Specializing in Porsche cars
http://www.systemsc.com/
Loren
