993 Forum 1995-1998
A Plug-and-Play, DIY-Installable 993 Immobilizer Defeat
Old 09-14-2019, 08:23 PM
NC TRACKRAT
NC TRACKRAT's Avatar
Originally Posted by Jay777
A sequence of ignition key strokes (ala FOB programming) could be used to revert back and forth between immob and demob. Not in the current prototype but easy to add. Great idea.
Outstanding! As an aside, I retired from AMP Incorporated just before the TYCO take-over but was associated with the Communications side rather than the Automotive. The plug for that receptacle looks identical to the one already installed. In many instances, depending on the customer, certain connectors were restricted. If you can identify the manufacturer of the Immobilizer Module, I'll see if I can check with some of my sources to identify and determine the availability. Send me a PM if you do.
Old 09-14-2019, 08:31 PM
Mr.Woolery
Mr.Woolery's Avatar
Count me in as interested.
Old 09-14-2019, 09:02 PM
Madturk
Madturk's Avatar
That’s great... I’m in as well. Thanks for the effort
Old 09-14-2019, 09:06 PM
Jay777
Jay777's Avatar
Wow, what a coincidence. The body of the plug on the right looks to be the same as the one on the left but the pins are a different pitch. Regardless, the 3 port receptacle is a single component made by AMP. I see no mfg name on the board, just “ Made in Australia”. I recall in my research coming across the name of a mfg but can’t remember where. Need some help. Would be really nice to make this as plug- and- play as possible. Thanks NC.
Old 09-14-2019, 09:24 PM
mhm993
mhm993's Avatar
Everyone is interested in this
Old 09-14-2019, 09:40 PM
pp000830
pp000830's Avatar
Received 1,481 Likes on 1,044 Posts
Originally Posted by tstafford
Car is already protected - it’s stick shift. No one can drive them any more.
Not true, only proves the guy who stole it is over 50 years old!
Old 09-14-2019, 09:58 PM
Jay777
Jay777's Avatar
Isn't that all of us??
Old 09-14-2019, 10:36 PM
tdarby
tdarby's Avatar
Keep us updated
Old 09-15-2019, 11:39 AM
Allen
Allen's Avatar
Old 09-15-2019, 12:08 PM
pp000830
pp000830's Avatar
Andy - the current prototype mounts inside the immo box but there's a chance the receptacle on the right side of the pic below can be used to mount the "demob" module. The receptacle says "AMP" on it (now TE Connectivity), but there are no other visible part numbers. Not sure what it's used for - nothing's plugged into it on my car and the schematics make no reference to it. Maybe a factory test jack?
One of the goals will be to make the mod as DIY friendly as possible, so if anyone has a lead on the part number and/or source for them it would be a big help. (An immobilizer schematic would be nice too!)
I wonder if the pins can be purchased from TE for the middle connector that is unused. If available it could be populated for the same purpose and in doing this there is no need to repurpose the right-hand socket.
Having all the active components external to the unit would make the upgrade completely reversible by simply unplugging it. Then again if the fix turns out to be reliable why would anyone bother to reverse it? KInd'a like replacing the anti-theft wheel nuts with standard ones, why go back?
Old 09-15-2019, 05:19 PM
jrmdir
jrmdir's Avatar
Subscribed. Thanks!
Old 09-16-2019, 12:50 PM
onelove
Basic Sponsor
onelove's Avatar
Also highly interested.
Instagram :Swine11 | TitanMotorsports
Swine11 ReBoot - 964 / 993 Shift Boot Trim Panel
2004 996 GT3 | 1986 Carrera 3.2 (future Keen Project) | 2016 Cayenne Diesel
Old 09-16-2019, 04:40 PM
drodg
drodg's Avatar
Very interested and over 50.......
Old 09-16-2019, 04:59 PM
Jupiterfish
Jupiterfish's Avatar
yes please.
Old 09-16-2019, 05:07 PM
SpeedyC2
SpeedyC2's Avatar
This sounds like a good thing!
Interested...
Quick Reply: A Plug-and-Play, DIY-Installable 993 Immobilizer Defeat
