Screw in tire
can I get a side view of that wheel?
If you are lucky it doesn't go in further than the tread block and can simply be removed.
To verify this fix when pulling it out without getting stranded with a flat time if it does leak is to...
Without even unmounting the tire, get a tire rope-plug kit at Harbor Freight for a few dollars and pull the screw out.
If it leaks just push the rope plug in with the tool that comes with the kit.
Although such a fix is not recommended for radial tires over time it will work just fine until you have time to take the tire in and have a proper plug put in from the inside face.
Tubeless Tire Repair Kit
Some folks in a pinch keep a rope-plug kit in their car with their spare tire as an emergency repair option rather than filling their tire up with goop.
Andy
Andy
Don't screw with it, no pun intended. Take it to your local Discount Tire store. They will dismount the tire and fix it properly with an internal patch. I've had two new tires fixed by them, and they've never leaked.
I second this. Discount Tire is a great outfit. I use them for any car that doesn’t have centerlocks. Although I suspect they could handle that too.
The reason I suggested above that the OP check the screw to see if it went all the way through the tread is
I recently took my car in to have the rear tires dismounted and rotated.
The mechanic refused to dismount and rotate one of my tires to another rim because it had a screw in it, insisting it was dangerous and unsafe. I went home and dug the screw out myself. Turned out it didn't go in past the tread block and was a non-issue.
Some folks would have inferred by his comments that they needed to buy a new tire or even a set of tires.
That mechanic needed to stop with the screw, and trying to mount his customer and dismount the tire.
More recently I have purchased tires from Discount Tire mailorder and NTB locally. I have had good experience however I question the value of NTB's road hazard warranty as it only covers the cost of the tire carcass not the unmounting, remounting, revalving and balancing of a replacement tire and is a fee on each tire at purchase.
Andy
Andy
Originally Posted by 993RS
Do not know how screws can enter tire... and twice in less than two weeks. First the front tire, then the rear tire.
Just had this happen to me a couple weeks back. I replaced the tire just in case I decide to hit the track. If street use at modest speeds, internal patch is the way to go. If tracked, you're sadly in for a new tire.
Buy your tires from Tire Rack(no affiliation) . They have a free two year road hazard insurance included with most purchases and just honored mine on rear 285 /30 18" at no joking 1 year and 363 days for full replacement value.
So do Discount Tire.
https://www.tires-easy.com seems to offer lots of economical options by comparison.
Andy
What is a tread block?
