DSC Suspension Option for 964/993
Has anyone seen or install this yet?
I know from personal experience with 997 and 991's that DSC makes a great product..
https://www.dscsport.com/porsche/#964
Andy
Wow, that's cool as heck! Kudos to them. But it doesn't look like the shocks have onboard accelerometers or position sensors on each piston, which means the controller doesn't know what's going on, and thus behaves passively (without feedback). They even state you can use any springs you want, so without onboard sensors any pre-programmed damping settings are totally useless. Real-time-adjustments are only useful when you have some target/goal, something to minimize, etc., and for that you need shock sensors. Am I missing something?
So color me skeptical, especially at a price of $10k+.
FAQ on DSC
(No affiliation, I was just going through the website.)
This may answer some of your questions:
FAQ on DSC
FAQ on DSC
Thanks. I read that, plus some youtube videos (SEMA 2016 interview was good). And everything I posted above looks correct. This system is essentially a dude twisting the 2 ***** (rebound & compression) on normal adjustable shocks in real-time, based on factors like speed, steering angle, etc. For example, the controller says "brakes were applied, so turn the front rebound ***** 3 clicks." I wouldn't call that "smart" or "active" since it gets no feedback and there's nothing to optimize. Ultimately, the user still has to decide what baseline settings he wants, based on his feelz. Sorry, that's not good enough IMHO. They're about halfway there. It'll be transformative when they get the rest figured out!
Ran them on my viper. Worked wonders. Soft when needed and tighten up in an instant. They’ve been tested many times and proven to work quite well. Can say on the 964/993 though
I remember when DSC first came out a number of years ago and a Boxster was driven around VIR (I think by Randy Pobst, or maybe Mike Levitas?) with the system turned off/on and it was reported the laps times were significantly faster with the system on.
Regardless, it's too expensive for me. Seems like a step in the right direction, though, and I'm impressed they have spent the time to adapt it to older cars.
I'm not disagreeing, just trying to understand. The system is described as "active" in many locations, but I guess it's more marketing than fact? (I agree with you a system should have feedback to be considered active.) Still, it does note the program predicts the response needed, which sounds kinda of active...
1) It "predicts the response needed" by analyzing the inputs like brake force, g's, steering angle, etc. The processor runs that thru your mappings then calculates the desired shock setting. I'd call that "real time" not "active."
2) Some newer cars have ride-height sensors (i.e. damper position sensors!) that the system *might* be using in those calculations (I don't see any evidence that they are). But 993s don't have that. I'm not even sure can-bus gives sufficient data rate to properly use that.
