Best HID upgrade
#31
The kit come with both lens and hardware brackets for $160. Thats all you really need. The high beam spitter harness is optional, this is used if you are planing on using the orignal high beam along with the high beam in the projector lens. Harness will need some modification on the connectors to make it fit properly. If your buying the Tore kit you will not need any thing else, If your not using Tore's kit then you can by there HID ballast/bulb kit but it looks like it will not all fit with in the headlight assembly
Thats what had me so confused... I did not know the projector had its own high beam setting!! To be fair, I do not think this is disclosed anywhere on the website, and I am a newbie to all this modern tech stuff...
Will order this weekend.
#32
Using an HID bulb without a projector is a recipe for glare and poor dispersion. If you go with a projector, you can pretty much use any standard HID bulb.
Was there never a factory HID option for the 993?
#33
#34
Just to complicate things, I’ll tell of my adventure in lighting. I had the hid kit from Gert in my car and was pleased with the low beam but the original halogen high beam looked pretty anemic in comparison. I then installed the LED high beam kit from Cylops (I think) and high beams are wonderful by comparison with the original. Installation was tight but it all fit. Get a pentalobe driver if attempting this job.
#35
Well done!
#36
#37
I did this ^^^ and the Morimoto lens upgrade with Tore’s low beam HID bulbs. The Morimoto bi-HID setup has a solenoid splitter that lifts when the high beam is switch is engaged. The Morimoto projector is both high and low now. So essentially I have the Cyclops LED high beam AND the ‘opened’ projection beam all on when the high is engaged. It throws a tremendous amount of light. I did this all in stages, Tore’s HID then Cyclops LED and finally Morimoto projector. The final result is worth it and it’s all reversible for you purists.
I was thinking that maybe first doing the projector, then Tore's kit, and doing the Cyclops last, but am unsure. Like the OP, I'm on unfamiliar territory when it comes to lighting. Your suggestions/advice appreciated.
#38
Do you feel this is the best sequence for upgrading in stages?
#39
You are going to want to do Tore’s HID first and then Morimoto. This will render your current halogen high beam bulb useless. You may want to keep it this way and be just as happy with the result. Then later on if you want to add I bit more light on the high beam side install the Cyclops LED to replace the halogen bulb.
Thank you everyone who contributed. Thank you all for the pictures. As they say they are worth a thousand words.
I think this is the path I will follow...
Cheers,
#41
I would appreciate some illumination.
I have factory Litronics and they work well. The front lenses are a little cloudy.
Can I, should I modify with projectors or anything else?
Can I purchase the front glass lens portions?
#42
Of course you can just get the glass. I just bought a set and found them cheapest, at $125 each, here: https://www.sunsetporscheparts.com/a...omponents-scat
Looks like they are now $135. My mistake, I actually ordered from Suncoast in FL at $125 each. Sunset is closer to you.
Mine had haze on the lens so I simply used a cotton swab and wiped down the outside of the lens. Did not want to disassemble to get to the backside of the glass. You could also upgrade the hi beam bulbs like I did with something like a Phillips Xtreme vision bulb.
https://www.amazon.com/Philips-X-treme-Vision-Headlight-Bulbs/dp/B00QJWTQOE/ref=sr_1_8?s=automotive&ie=UTF8&qid=1512231565&sr=1-8&keywords=h1+headlight+bulb
Just be aware that these upgraded bulbs only have a 400 hr life vs stock at 800+ hrs, which I was fine with.
![https://www.amazon.com/Philips-X-treme-Vision-Headlight-Bulbs/dp/B00QJWTQOE/ref=sr_1_8?s=automotive&ie=UTF8&qid=1512231565&sr=1-8&keywords=h1+headlight+bulb](https://rennlist.com/forums/images/misc/amazon_icon.gif)
#43
#44
Insides of lenses covering Litronics were hazy. Removed them and cleaned the insides- noticeable difference in appearance and improvement in light output Replaced high beam bulbs with Philips 130% recommended by an earlier thread.
