PSS-9 Settings
I seem to recall some talk about "6" for the street and "2" or "3" for the track.
Also, would there be any reason to set front and rear to different settings?
Thanks.
Start with middle setting all around.
Tune your sway bars for the corner entry Under/Oversteer you want.
Tune the shocks for the mid corner Under/Oversteer you want.
Soften the shocks all around if the car will not settle quick enough in transitions.
Hope this helps.
The other reason is the clickers on my PSS-9's are nearly impossible to set by feel and are very difficult to see, even with a flashlight and mirror. Since I run only full soft or full hard, I don't have to see or feel the clickers. Just turn them full clockwise or counter.
MC
Street: Bars- middle/middle Shocks- 6/6
Track: Bars- 1 less than full stiff in front,full stiff in back Shocks- front 1,rear 2
I've had this set up with both 17" Kumho 225/255 and 18" Hoosiers 245/285. I've been on small tight tracks like Gingerman and Grattan, and on Mid Ohio and Watkins Glen. I find the street settings fine, but the track settings still a little soft. But, they do provide a good compromise, and I can move the rear around when I want to, but it doesn't get too loose. I'm not sure I can tell the difference between increments of 1 step on the shocks. I've tried these settings, though, and like them. Hope this helps. <img src="graemlins/burnout.gif" border="0" alt="[burnout]" />
) with RS bars on middle/middle. Even with monoballs all around and nylon bushes in the front wishbones I find the ride at 6 fine for daily street use.
Middle settings stiff for street but, I like it that way.....do not imagine i will go softer except for rain days at the track.
Ted
PSS9's set full stiff (1) all the way around.
Sway bars front and back were full soft both front and rear (sway bars are TRG's 25 front 22 rear) so these are fairly stiff).
Tires were Pirelli slicks D5's front D4's rear.
Camber is about 3.5 front 3.0 rear.
This set up given the cool temperatures worked out very well. Could get oversteer when needed or simply four wheel drift as needed. It was excellent. Can't wait to go there again even though the walls are close by and a guy in front of me actually hit the wall coming out of turn 11. Got it on tape
I saw your car there. Setup looked very nice. Were you timing your laps? If so, what times were you running? I was driving in DE group 1 and was a guest instructor in DE group 2. If I'd known you were a fellow Rennlister I would have introduced myself.
Matt
On the track I'm still experimenting. I usually drive at Sebring which is a pretty rough track and the full stiff seemed like too much....right in the middle seems to work well down there.
C
I was supposed to be in DE #1 but some how ended up in DE #2. That was a big mistake since all I did was pass cars. My lap times suffered since we could only pass in three spots on the first day. The second day was better but still not much good for times. I also was not really at the edge of it all since those walls look pretty large in certain places
I was running right a 2 minutes given the conditions which is not fast but was really fun. How were you running for times?
I was able to run consistent 2:02's througout the weekend. There were a few faster runners in the group but your 2:00's would have put you in the top 5 (of 40). VERY respectable! Most of the cars in DE1 were running 2:04 - 2:10's by my estimation.
I'll look for you next time.
Matt
