Starting w/out Depressing Clutch
Who's 993 will start without pressing the clutch? My '96 does. Just realized this the other day, since depressing the clutch on cars to start them has been embedded in my brain.
Is this an issue with the microswitch or did certain years not have this safety feature?
Mine is a 96' C4S and it also starts without depressing the clutch.
As does my 96, at least they never added those electric garage door opener seat belts attached to the doors the VW had on their cars for a while. Our cars came from a period where the primary piece of safety equipment was the operator of the vehicle. I guess the having-to-put-you-foot-on-the-peddle on 97' on cars was the very beginning of the end of this in modern automotive technology.
My '96 also starts without the clutch depressed.
I vaguely remember someone's blurb on here about how it's actually preferable to start without the clutch pedal depressed... something about how the force from the pressure plate is hard on the crankshaft bearings during startup.
Yeah, it's a "safety feature". Yet another instance of "Big Brother" looking out for clueless drivers. As stated above, failure of that microswitch can leave you stranded with a vehicle that won't start. Just after getting the C2S a few years ago, it began to intermittently not start. Thanks to this forum, I realized this was the culprit, by-passed it and it hasn't failed to start since. (knock on wood!)
enjoytheride,
I've also been taught to start the engine with gearbox in neutral, clutch out. Having the clutch in puts excessive pressure on cold, poorly lubricated bearings.
I was also taught to select neutral and take my foot off the clutch at traffic lights, to reduce clutch wear.
Not sure of the accuracy of these ideas, but old habits die hard.
enjoytheride,
