Timing chain cover material ?
Just doing an engine refresh and have noticed that the timing chain covers looks ugly. The valve covers can be cleaned and look great but you can't seem to improve the looks of those covers. Do they all look like this even when new? Has anyone painted them with long lasting results? thanks Doug
Seared
Doug,
I assume they're either magnesium or aluminum. As such, you could probably scuff the surface, clean thoroughly with a prep solvent, and then paint using a high-temp engine paint.
Andreas
Andreas
Doug, they all look like that. If I were to paint them, as a minimum, powder coat them - outer surface only. That is as permanent a finish that can be had.
The valve covers are non-metallic, except for the bushings.
Seared
The material used on the chain covers is bakelite, known today more as Glass-Phenolic Laminate. Very rough surface hard to clean or paint.
Doug,
We use the bakelite material alot in the electrical industry as an insulator. I am familiar with it's composition and I don't think painting it is a great idea. And, of course, they can't be powder coated. I would give them a good cleaning and save yourself a hassle down the road.
Andreas .. Shoe Polish! I actually found that in an article about restoring Bakelite antique phones.
You may find the Bakelite has faded badly; your options are to dye or paint. Black shoe polish can be quite effective to fill the minute pits; let it harden for ten minutes, then wipe off the remainder with a kitchen paper towel and buff with a duster.
Doug
Doug
Out of curiosity, why would you recommend not painting them, especially with an appropriate paint? You worried about peeling, or ?
Technical Guru
