How to repair a bent front jack point
That's why I said its not an issue that needs to be included on PPI before you buy a car. I don't think its worth worrying about.
My wheel guy was in pissy mood a few weeks ago, complaining that he was unable to properly jack up the car with a bent jack point. I bent down, inserted a hockey puck, and walked away. Works like a charm.
I used hockey pucks all the time with the lift.
I would say a good 50% of the 993's I see have bent jack points, and it seems to be always the front drivers side. That side appears to be weaker.
It bends because one of the spot welds break - you need to reweld it to fix it correctly. That is NOT just welding, then you need to clean it, prime and paint BOTH inside and out or you are asking for rust. I would rather just use a hockey puck, works fine on a bent point.
Cheers,
Mike
Cheers,
Mike
