The PENULTIMATE wheel weight thread
Old 06-06-2024, 12:05 AM
f4bones
f4bones's Avatar
Default The PENULTIMATE wheel weight thread
As I wander through my journey to the ultimate 992, one critical factor is wheel selection. As I found out the hard way, wheel weights are HIGHLY variable, and seemingly similar wheels can have dramatic weight differences. Thus, I thought I start this thread to list actual wheel weights. While my inventory is limited to 992 TTS and GT3 models, my hope is that other will contribute and post actual, accurate weights for others looking to make an educated decision. I weighted these today on a recently calibrated scale, so weights should be within 1/10 / LB. Here we go!!
First, here is my set of Meisterwerk P101 copies:
Meisterwerk 20x9.50 ET45 Front - 27.6 LBS
Meisterwerk 21x12.50 ET48 Rear - 34.8 LBS
Next, stock GT3:
Stock 20x9.50 ET45 Front - 21.2 LBS
Stock 21x12.50 ET48 Rear - 26.2 LBS
Next the TTS "sport package" wheels (same wheel, but different color):
Front 20 x 9.0 ET 41 21.2 lbs
Rear 21 x 11.5 ET 67 24.8 lbs
Last, the new Manthay GT3 Wheels:
Front 20 x 9.5 ET 46 18.0 Lbs
Rear 21 x 12 ET 45 22.2 Lbs
I have two sets of HREs - a standard P101 on my TTS, and a P101LW on the GT3. Those are mounted up right now, but next tire change I will post weights. My guess is that the P101LWs are pretty darn close to the Manthay wheels. The finish on the Manthay wheels is AMAZING - beautiful wheels. Those are going on my GT3T as soon as it's back from Deman / M-Engineering for the 4.5L upgrade!!
The following 5 users liked this post by f4bones:
aarodynamics (06-12-2024), Aaron Lin (06-06-2024), dixonk (06-06-2024), RealityGT (06-06-2024), rickawd (06-06-2024)
Old 06-06-2024, 12:21 AM
Bluehighways
Bluehighways's Avatar
Received 2,647 Likes on 1,246 Posts
I'm guessing by the weight figures you're listing that these are weights without the tires. Weights without the tires are what is the valuable information.
FWIW, Tire weights can be all over the map, but are just as important when going shopping, Even more so, because of their dynamic location and its effects relative to the suspension points.
Old 06-06-2024, 12:26 AM
f4bones
f4bones's Avatar
Yes, weights above are without tires or TPMS. . . I have a good selection of tires as well, so will post weights for the various flavors of tires as well.
The following 4 users liked this post by f4bones:
Aaron Lin (06-06-2024), dixonk (06-06-2024), rickawd (06-06-2024), rmb1973 (06-06-2024)
Old 06-06-2024, 09:47 AM
Shogunade
Shogunade's Avatar
Received 1,880 Likes on 1,056 Posts
The Mantheys sure are purdy. Definitely have to coat the cutouts well.
Old 06-06-2024, 09:57 AM
tourenwagen
tourenwagen's Avatar
Received 4,319 Likes on 1,183 Posts
If this is the penultimate thread, when does the final one drop?
The following 6 users liked this post by tourenwagen:
alaris (06-08-2024), Fishah (06-06-2024), Jeff Whitten (06-06-2024), Larson E. Rapp (06-08-2024), TempeAndy (06-06-2024), VarTheVar (06-06-2024) and 1 others liked this post. (Show less...)
Old 06-06-2024, 10:44 AM
Tobeit
Tobeit's Avatar
Received 1,462 Likes on 728 Posts
(1) Stock Exclusive Design - monoblock forged
Front 20x8.5 - 22lbs
Rear 21x11.5 -28lb
(2) BCForged, 2pcs forged (similar weight as your Meisterwerk)
Front 20x8.5 - 26lbs
Rear 21x11.5 -34lb
f4bones (06-06-2024)
Old 06-06-2024, 12:48 PM
f4bones
f4bones's Avatar
Penultimate was tongue in cheek - you never get the last word on Rennlist . ..
The following 7 users liked this post by f4bones:
CJDCREW (06-08-2024), Jeff Whitten (06-06-2024), mthreat (06-06-2024), NEH51 (06-06-2024), TK42ONE (06-07-2024), tourenwagen (06-10-2024), VarTheVar (06-06-2024) and 2 others liked this post. (Show less...)
Old 06-06-2024, 06:58 PM
pal
pal's Avatar
2024 GTS centerlock wheels, with factory Pirelli tires.
20x8.5et50, 245/35: 44 lbs
20x11.5et67, 305/30: 58 lbs
Aaron Lin (06-12-2024)
Old 06-06-2024, 07:01 PM
f4bones
f4bones's Avatar
kind of hard to compare w tires - if you get a chance, please post weights next time you change tires w/o tires . . . thanks!! I suspect those will be quite similar to the TTS wheels, which are actually pretty light. . .
Old 06-06-2024, 07:13 PM
pal
pal's Avatar
Yeah, I saw your original post and debated whether I should post these at all. And just posted. It may be a while when I change tires, but will do what you ask, when I do.
FWIW, TireRack lists the OEM NA Pirellis at 22lbs for the front and 32lbs for the rear, putting the wheels at 22lbs front, and 26lbs for the rear. This puts them within the ballpark of the TTS wheels.
LMK if you’d like me to delete my posts to reduce noise on your thread?
Old 06-06-2024, 07:15 PM
f4bones
f4bones's Avatar
No - this is great - some data is better than no data, and this tire data is probably pretty accurate, and foots with what we would expect. These are very reasonable weight wheels - well done Porsche.
Old 06-08-2024, 01:11 PM
Corsa Forged
Premium Sponsor
Corsa Forged's Avatar
That is ridiculously heavy for monoblock wheels.
Corsa Forged // Corsa Forged LLC 🇺🇸
Fully Bespoke Performance Forged Wheels
Follow us on Instagram: @Corsawheels / Facebook @Corsa Forged
Sales: Corsaforged@gmail.com // +813.449.0349
Old 06-08-2024, 01:23 PM
Corsa Forged
Premium Sponsor
These would be lighter than OEM if kept the same specs—right around the same weight with increased widths and offsets.
Old 06-08-2024, 04:02 PM
Tobeit
Tobeit's Avatar
as the title says, provide actual weights instead bashing. This is not a wheels advertisement thread.
Jeff Whitten (06-09-2024)
Old 06-08-2024, 04:27 PM
M3Inline6
M3Inline6's Avatar
Received 1,797 Likes on 971 Posts
Now I wish I had weighed my HRE’s before mounting them.
Quick Reply: The PENULTIMATE wheel weight thread
