Radar Detectors
Old 06-03-2024, 09:07 PM
dvu
dvu's Avatar
Originally Posted by Richard H Stamps
Radenso and a suction cup mount from Etsy that fits perfectly. I move the radar detector between my 992 and my Macan
Since you switch it btwn vehicles, how do you power it? I don't see myself using it all the time (bad example for the kids), wasn't planning on hardwiring it in. thx
Old 06-03-2024, 09:19 PM
PhilH930
PhilH930's Avatar
I went with an Escort Redline 360c. Was able to sample a few and they all have their strengths. I settled on wanting directional arrows and preferred the build quality of the 360c. Was previously mounted in 718 using the suction cup, but bought the blendmount for 992. Yet to install but impressed by how small the blendmount is.
The following 2 users liked this post by PhilH930:
REIN911 (06-04-2024), silverscooby27 (06-04-2024)
Old 06-03-2024, 09:36 PM
needmoregarage
needmoregarage's Avatar
Received 1,475 Likes on 638 Posts
So far, we have avoided a permanent mount, not wanting anything mounted in the car that “signals” a valuable item inside.
We leave nothing in view (ever). We live in a nice, safe area - but it’s been our habit for a long time whether running local errands or traveling.
We’ve not had an issue with the suction cup mounts. It would be nice to have a built in power supply, but so far we haven’t done that either.
Old 06-03-2024, 10:31 PM
ddreyfu76
ddreyfu76's Avatar
Originally Posted by m732sg
R7 with mirror tap but no blendmount
Same here
Old 06-03-2024, 11:04 PM
Daytona67
Daytona67's Avatar
I'm in the search process as well. Probably going with a Uniden R4 or Escort Max 4 for smaller profile but no arrows. Escort has the nice magnetic windshield mount.
Old 06-03-2024, 11:17 PM
Icegrill
Icegrill's Avatar
V1 Gen 2 alerted me a good 2-3 minutes of the ‘bogey’😂
Old 06-03-2024, 11:50 PM
Risley
Risley's Avatar
Radenso Pro M. Was going to try the new V1 Gen 2. Valentine doesn't answer their phones.......EVER! F' them!
How are these R7' & R8's guys ? Whats the difference between the 7 & 8 ?
Old 06-04-2024, 12:06 PM
malba2366
malba2366's Avatar
Biggest difference is that R8 has auto lockouts, like Escort has had for any years. So if you drive by the same CVS with automatic doors 3 times within a certain period the R8 will remember and block that signal automatically.
R8 also has improved range...how much that matters is questionable because the R7 was already very good.
Risley (06-04-2024)
Old 06-04-2024, 12:18 PM
clooloss
clooloss's Avatar
I use the Escort Maxcam 360c and Blendmount. This detector got a bad rap due to the crappy app that Escort makes, but the radar detector itself is really good. If you try and access the videos from the app you'll be very frustrated but if you have the dashcam as a 'just in case' that you can view later on your computer, I have not found a better solution.
Also, if you use the Valentine V1 gen 2, get the V1 driver app. Does a great job at automatically filtering false alarms, etc.
The following 2 users liked this post by clooloss:
needmoregarage (06-04-2024), rasetsu (06-04-2024)
Old 06-04-2024, 12:27 PM
shindrome
shindrome's Avatar
I have a '24 C2S with no prewiring for dashcam but would like to install one including a radar detector. Are there any good resources on how to install both and wire them to the existing power supply in the mirror? Any feedback would be appreciated!
TKDbilly (06-04-2024)
Old 06-04-2024, 12:40 PM
needmoregarage
+1^
Old 06-04-2024, 12:57 PM
jlegelis
jlegelis's Avatar
There are a few long threads on this... use google to search rennlist and it'll pop up
Old 06-04-2024, 01:00 PM
rasetsu
rasetsu's Avatar
I used to move a detector in between three cars and hardwire is by far the most convenient. Just install hardwire kits in each car. Hardwire doesn't mean you have to have your detector permanently attached and it's a not a big deal at all to install. If you don't want to remove any of the overhead map light cover or rear view mirror cover to utilize a mirror tap, you can run an Add-a-Circuit from the footwell fuse panel and run the cord up the A-pillar in between the windshield without needing to remove any panels. When you hardwire, all that is visible is the RJ11 phone jack cord that you can tuck up behind your review mirror when you don't need it.
dvu (06-09-2024)
Old 06-04-2024, 02:37 PM
Harbortime
Harbortime's Avatar
I have an Escort Max CI 360. Laser jammer front and rear. https://radartest.com/escort-max-ci-review.asp
Old 06-04-2024, 05:42 PM
2022_992
2022_992's Avatar
I have been using the Redline 360c with a blendmount for 2 years now, no complaints
Quick Reply: Radar Detectors
