The new 992.2 GTS faster than the 992.1 in 8.7 Seconds at Nürburgring
Old 05-13-2024, 09:42 AM
Wilder
Wilder's Avatar
Received 5,005 Likes on 1,777 Posts
Originally Posted by silversurfer6
Faster than the 992.2 Turbo S also it seems - I find this hard to believe to be honest. Maybe tyres?
You mean 992.1? Porsche tests cars exactly as they come out of the assembly line.
Old 05-13-2024, 09:57 AM
MacAna
MacAna's Avatar
As per press release:
The test car was equipped with standard road tyres, plus the aero kit with a fixed rear wing that has been available as an option for several model generations now, and which provides increased downforce at high speeds.
Old 05-13-2024, 10:11 AM
R N M
R N M's Avatar
The beginning of the end is here - ZERO interest in a hybrid 911. Obviously that means no more manuals on this version.
Old 05-13-2024, 10:17 AM
22992's Avatar
I won't be surprised if the GTS comes with Cup 2's instead PS4S with those times.
Old 05-13-2024, 10:25 AM
Tobeit
Tobeit's Avatar
Received 1,487 Likes on 734 Posts
May 28th will be interesting to finally learn what versions/configurations will be available. We had enough speculations, for sure. I am particular keen to learn if there will be a base or whatever version that sticks with ICE only or if the 992.1 is truly the last generation of its kind. If so, I sure would love me a T.
Trilander (05-15-2024)
Old 05-13-2024, 10:28 AM
silversurfer6
silversurfer6's Avatar
Exactly what I meant!
The following 2 users liked this post by silversurfer6:
22992 (05-13-2024), Wilder (05-13-2024)
jlegelis
jlegelis's Avatar
... until all the breathless prose on the 'torque fill' or the hybrid begins to fill our feeds..
Old 05-13-2024, 10:36 AM
Ksdaoski
Ksdaoski's Avatar
Received 1,802 Likes on 902 Posts
Originally Posted by R N M
The beginning of the end is here.
How many times has this been shouted since the Internationale Automobil-Ausstellung (Frankfurt Motor Show) in Frankfurt in September 1963, with the launch of the 901?
The following 10 users liked this post by Ksdaoski:
GuardsRed992 (05-13-2024), Haros (05-13-2024), incoming992s (05-13-2024), jlegelis (05-13-2024), mashoutposse (05-13-2024), rasetsu (05-13-2024), snakepilot 69 (05-13-2024), tourenwagen (05-13-2024), UncleDude (05-13-2024), Wilder (05-13-2024) and 5 others liked this post. (Show less...)
Old 05-13-2024, 11:10 AM
shrimp money
shrimp money's Avatar
Received 5,104 Likes on 2,040 Posts
Originally Posted by DocM
Checks out!! That one time where math is helpful...
WHEN AM I EVER GOING TO NEED TO USE THIS IN LIFE?
When calculating which 911 model Porsche tested.
The following 6 users liked this post by shrimp money:
alaris (05-14-2024), cwbrown (05-13-2024), DocM (05-13-2024), mashoutposse (05-13-2024), pal (05-13-2024), user 999993337 (05-13-2024) and 1 others liked this post. (Show less...)
Old 05-13-2024, 11:26 AM
pal
pal's Avatar
Please remember that the hybrid technology on the GTS is T-HEV. This is basically an e-turbo and not a hybrid car as most people think. The extra weight should be less than 100kg maybe even around 60kg since only one turbo is present and no dual mass flywheel is needed.
Ah, if true, a single turbo, with electronic (spool) assist, could be quite interesting. It could basically have the response of a normally aspirated motor off the line, and the flat torque of a turbo through the rev band. And, a single turbo should also noticeably change the exhaust note. If the rest of the motor is unchanged, I don’t see why Porsche cannot offer a manual as an option on such a motor.
Old 05-13-2024, 11:28 AM
ipse dixit
ipse dixit's Avatar
Received 11,657 Likes on 5,110 Posts
Originally Posted by rk-d
The progress continues. But do 'Ring times really resonate anymore? Am I convinced a newer car is a better experience because of its 'Ring times?
I don't think I care anymore. I bet Porsche could make a 911 EV that would blow every record out of the water.
I think in the entire automotive universe, only Porsche has that extreme level of fascination and myopic focus on Ring times.
They essentially build cars to a specific Ring time.
Other marques care, but their level of interest compared to Porsche's is like comparing a pothole to the Grand Canyon.
Old 05-13-2024, 11:39 AM
3-Pedals
3-Pedals's Avatar
Received 1,651 Likes on 918 Posts
220 lbs weight penalty negates almost half of the claimed power bump. When you factor this in, the power bump is around 6-7% which is inline with prior gen increases. I believe they have bumped the power 5.5-6% on paper but they did reduce the weight at times (or allowed car to be configured in a way that allows weight reduction).
Old 05-13-2024, 11:47 AM
Vicbastige
Vicbastige's Avatar
Wait, am I to understand there will be no ICE only 992 GTS available? That be the case I'll be burried in my current one.
Old 05-13-2024, 11:50 AM
3-Pedals
3-Pedals's Avatar
No ICE only GTS and Turbo S.
Old 05-13-2024, 11:53 AM
Schn3ll
Schn3ll's Avatar
Received 1,074 Likes on 448 Posts
No manuals either is my guess. And I think we can throw out the naturally aspirated GTS rumor as well - this is certainly turbocharged.
I just hope they don't use archaic Li-Ion batteries and go with super capacitors ala Sian.
Quick Reply: The new 992.2 GTS faster than the 992.1 in 8.7 Seconds at Nürburgring
