Does lowering the 992 void warranty?
I just picked up a new 24 992, I asked the dealer if I changed the springs to lower the car would it void the warranty. He said that it would because if I for instance brought it in for noises such as squeaks, they wouldn’t be able to rule out the cause being the springs.
i did a search on rennlist and saw a post “mods that don’t void your warranty” and lowering springs was in there although someone said it might.
Any definitive answer on this topic?
thanks in advance
thanks in advance
Once again…. For the people sleeping in the back: It will only void certain parts and systems. Those of which could be connected to the installation non oem springs.
The following 2 users liked this post by Icegrill:
Highline-Autos.com (05-07-2024),
Mike818 (05-07-2024)
thanks in advance
thanks in advance
So they may not fix stuff that's directly impacted by the suspension mods, like if you run springs and your stock shocks wear out prematurely, but I think it would be insane if they try to not address rattling or squeaking issues inside your car simply because you installed springs.
The Magnusson-Moss act basically says the dealer has to show whatever modification caused the problem you’re trying to get them to fix. It cannot void the entire warranty. For instance, if you lower the car but then have an engine problem, there is no nexus between the two. But if you chip the engine and it runs too much boost and you punch a hole in the block, they can probably weasel out of paying for repairs.
It won’t void coverage for everything on the car, but yeah, any suspension related failures, excessive wear on bearings/bushings, and likely squeaks/rattles will be blamed on your lowered car.
If you go low enough where it is evident that hard bits are striking the ground, you can expect problems with warranty claims for those areas as well. For example, if the engine manages to make impact, that’s going to be on you.
alaris (05-07-2024)
The answer is YES.
But as always, the devil is in the details.
BIGWORM (05-07-2024)
Basic Sponsor
Bingo! They can not void a PCM, water pump, or PDK claim just because a customer is running lowering springs.
Your place for distinguished automobiles, proud provider of Fidelity & Freedom Warranty extended warranties. Visit us at Highline-Autos.com
Official RECARO Automotive Retailer: www.highline-autos.com/product-category/recaro/
Highline Autos Magazine - Volume XXI, Issue 03 https://bit.ly/3wTsNzM
Platinum Sponsor
if you lowered the car and have problems with the suspension parts, the dealership might blame your upgrade and wont fix it for free
but they cant deny a claim a defective headlight that stopped working or a bad turbo
If you leave a car 100% stock, what's covered under warranty and what isn't is pretty clear....and it's STILL sometimes difficult to get things fixed. You mod your car in any way and you're living in a grey area, where a claim may or may not be denied, and if the mod can even be remotely related to a failed component you're potentially facing a batlle. Lowering springs COULD affect everything related to physical suspension, as well as electronics that monitor yaw/roll, squeaks/rattles...heck a (weak) case could even be made that lowering a car can affect airlow and thus the entire cooling system...well you get the picture. My approach is leave it stock, or mod the heck out of it and be prepared to pretty much kiss your warranty goodbye.
In reality shops don't get paid to not fix your car.
Considering as you move up the performance ladder, the aero increases and usually ride height decreases, it seems like a huge jump to get to lowering = cooling system issues.
Let's run with that anyway though. Let's say I lower the car and I have cooling system "issues". I assume that would be overheating? Anyway let's say I bring my lowered car to the dealer and they tell me lowering my car has messed up my cooling system efficiency and that is why I am over heating.
That is an easy hypothesis to test. I can swap back to stock, and if my problem is fixed, then all good. If the problem persists then they can go ahead and fix it under warranty. You could let them swap the springs and offer to pay for it if it fixes the problem. You could swap them back yourself and when it doesn't fix the problem get them to do the labor or reimburse you etc. How you choose to handle the problem would be dependent on your particular situation.
