Newbie and Question on Homelink
Old 04-02-2024, 09:09 AM
Zman1970
Zman1970's Avatar
Default Newbie and Question on Homelink
Hi all - just received a CPO 2023 Targa GTS - after 18 months of searching for the right one!
Question: I got homelink setup with my garage door - when I back out of the garage the reverse camera is on - I had to close the camera window and then go back to homelink to close the door, but then i had to put the car back in park, then reverse to get the camera back on...is there a better way of doing this?
Old 04-02-2024, 09:16 AM
tomtomtomtom
tomtomtomtom's Avatar
Congrats on the car. That's how Homelink works for me but I don't have to put in park. As soon as I close the camera window, I can close the garage door. As soon as I release the foot brake, the camera reactivates. Do a search on this forum. There are long stories pro and con about Homelink.
Old 04-02-2024, 09:40 AM
davidgriffith
davidgriffith's Avatar
There's a quick shortcut to switch between homelink and cameras on the lower right hand side of the screen.
When I back out of the garage the little icon shows a house for homelink, half way down the drive I tap the house which switches the camera view to the homelink options, press/ hold the garage door then tap the little camera icon in the same spot to bring back up the back up cam before i reverse onto the street. Definitely not as easy as the old roof mounted homelink or the automatic gps homelink in my gf's tesla but that's what we got.
Car: 2022 911 (latest PCM)
Old 04-02-2024, 09:56 AM
1BTD
1BTD's Avatar
I programmed the diamond shaped “optional” button for homelink-works great.
The following 6 users liked this post by 1BTD:
dg108 (04-02-2024), drcollie (04-02-2024), Jeff Whitten (04-02-2024), Shambler (04-02-2024), tomtomtomtom (04-02-2024), txpackers (04-03-2024) and 1 others liked this post. (Show less...)
Old 04-02-2024, 10:14 AM
HudsonOH992GTS
HudsonOH992GTS's Avatar
It is a bit clunky- I also programmed the diamond button for home link. The other trick is that the car has to be running (or at least accessories on) to utilize.
Old 04-02-2024, 10:43 AM
pal
pal's Avatar
But, but, that’s to turn Auto Start/Stop off
I tried to program Homelink on my new GTS yesterday and failed at the synchronization step. Gave up after a few tries. Need to read the manual for rolling code openers.
davidgriffith (04-02-2024)
Old 04-02-2024, 11:02 AM
6sigma
6sigma's Avatar
I've never understood why German cars do this. Super annoying. You have to start the engine in a closed garage and deal with the noise and fumes before you can open the door. Then when you pull in the garage you have to close the door with the engine running as you can't operate the opener with the car off. It's completely backwards. I've noticed this on several German cars, have no idea why they do it this way.
Old 04-02-2024, 11:45 AM
kim9701
kim9701's Avatar
When I back out of the garage, the Homelink Icon shows up on the right side of the PCM screen (while the back up camera is on). You can touch that icon to initiate the garage door close. I also have a programmable button set up as well.
Old 04-02-2024, 12:07 PM
davidgriffith
Same I use this for start / stop. I hate the car stalling out at lights.
@PORSCHE if you’re reading this please give us a 3-4 programmable buttons so I can set up my 2 driving moods (daily / sporty) and determine my own critical functions so I don’t have to deal with any more stupid screens
Old 04-02-2024, 12:18 PM
pal
pal's Avatar
My BMWs (M2 and Supra) have 8 programmable memory buttons. While overkill, I have all 8 programmed for fast access to things I use often; and this is in addition to 3 HomeLink buttons on the rear view mirror. Porcha could have given us 3 + the steering wheel.
Old 04-02-2024, 01:33 PM
tna3
tna3's Avatar
I guess it’s a security thing. They want to confirm you have the key for the car before allowing to open other doors. The home link will work also in accessory mode with the engine off but you do need a key. It’s a bit overkill I agree.
Old 04-02-2024, 01:45 PM
kim9701
kim9701's Avatar
In addition to the diamond programmable button on the steering wheel, aren't there two more programmable buttons on the dashboard?
Old 04-02-2024, 01:48 PM
adm63
adm63's Avatar
Depends on which options your car has equipped, if you have sports exhaust and/or nose lift for example the switches for those functions take place of the diamond switches on the dash.
Old 04-02-2024, 01:49 PM
Zman1970
Zman1970's Avatar
Thanks all - i didn't notice the homelink icon when backing up - that worked - i just pressed that with the reverse camera on and that did the trick. Appreciate all the help
Old 04-02-2024, 06:24 PM
Shambler
Shambler's Avatar
I find this very annoying, too.
My daughter's Mini does the same thing.
Quick Reply: Newbie and Question on Homelink
