Carrera T vs. S vs. GTS
Old Jan 27, 2024 | 06:05 PM
alexb76's Avatar
alexb76
Default Carrera T vs. S vs. GTS
Hi all,
I know this has been debated a lot... BUT, I wanna know EXACTLY what is the TECHNICAL differences between these models, NOT STANDARD FEATURES! I find Porsche website is very hard to follow exact technical details, they don't show brake size, or rear diff, etc.. on their technical specs to compare easily.
- Engine
Are they all have the same engine?! Nick Murray claims so. Really? Same Turbo/internal/downpipe/exhaust?
Brakes
- I believe T has the base, small, ugly black brakes. I've seen many complain they don't keep up tracking. What's the cost to upgrade to Carrera S brakes
- Is GTS brakes the same as S?
Standard Suspension/Diff
- Does T come with rear locking diff and Base/S/GTS do not?
Performance upgrades you can't get?!
- Is there anything you're not allowed to option in T (rear steering, etc)
While I think in general T, is a better buy than base, in the used, or barely used market (under 5K miles). S seems to be similar pricing as T, which makes it a better value. I just cannot get over the T tiny brakes under massive wheels, by far the worst aspect of T.
PS. Sorry if all of these are answered, I did some search, but it was mostly opinions than facts.
Old Jan 27, 2024 | 06:36 PM
shrimp money's Avatar
shrimp money
There’s no difference.
Old Jan 27, 2024 | 06:37 PM
alexb76's Avatar
alexb76
So, all 4 engines are exactly the same, just different boost levels?!
Old Jan 27, 2024 | 06:42 PM
detansinn's Avatar
detansinn
Originally Posted by alexb76
Hi all,
- Engine
Brakes
S/GTS are mechanical the same in the engine bay with the same turbos. They are differentiated by the tune. While the engines themselves are very similar between the base/T and the S/GTS, it is my understanding that they are not identical.
With regards to brakes, the Base brakes are entirely adequate. S gets bigger brakes. GTS brakes come from the Turbo. GTS also gets the helper springs from the Turbo.
Base RWD is the only variant that doesn’t have LSD available or as an option. Base 4 has it as an option. Standard on all higher trims.
Base is the only trim where so called performance options are unavailable. This is where the T gets special treatment.
If you want a manual transmission with the Base engine, this is why the T exists for the 992 generation. A lightly optioned T is a great car. If you’re spec’ing a T into S territory, just get the S for the bigger brakes and more power. Note that the peak power and torque numbers don’t tell the full story — the S is substantially beefier in the lower revs. The GTS is an incremental bump over the S in this regard.
Old Jan 27, 2024 | 06:49 PM
alexb76's Avatar
alexb76
Thanks so much, exactly what I was looking for. I just looked at curb weights, and there's 10kg difference between Carrera and Carrera S, probably most due to larger brakes, and I assume larger standard wheels, but unclear is any internal is different.
As far as brakes on T, I am sure they're great for street, but I've seen quite a few post of them not working well on track. They also look tiny in the larger wheels.
Old Jan 27, 2024 | 07:00 PM
Fishah's Avatar
Fishah
T brakes are fine for the track with a simple pad swap.
Old Jan 27, 2024 | 08:05 PM
Mike818's Avatar
Mike818
Hi all,
- Engine
Are they all have the same engine?! Nick Murray claims so. Really? Same Turbo/internal/downpipe/exhaust? <<< Same long block but the S/GTS has a larger turbocharger and the GTS is tuned for a little more boost than the S.
Brakes
- I believe T has the base, small, ugly black brakes. I've seen many complain they don't keep up tracking. What's the cost to upgrade to Carrera S brakes <<< If you are going to upgrade the brakes for track go with something aftermarket without dust boots. They tend to degrade and need replacing if you track regularly. Cost will depend on new vs. used and OEM vs. Aftermarket
- Is GTS brakes the same as S? <<< No the GTS gets the brakes from the Turbo
- Does T come with rear locking diff and Base/S/GTS do not? << The Base doesn't come with the locker, but I believe the S/GTS do if you spec the manual. Base PDK gets an Open and S/GTS get an E-diff (AFAIK)
- Is there anything you're not allowed to option in T (rear steering, etc) <<<< Center lock wheels, bigger brakes, PDCC (If you consider it a performance upgrade), the GTS has a helper spring in the susp.
I tried to answer in bold to the best of my knowledge.
Old Jan 27, 2024 | 10:21 PM
aggie57's Avatar
aggie57
good summary
Old Jan 27, 2024 | 10:22 PM
aggie57's Avatar
aggie57
and truth be told the S brakes are the same, i.e. fine for the track with a simple pad swap. The standard pads are ‘ok’ up to a point.
Old Jan 27, 2024 | 10:34 PM
itrocks4u's Avatar
itrocks4u
Hi all,
- Engine
Brakes
What are you trying to accomplish?
You should get the GTS, if not possible, then S and finally T.
Old Jan 28, 2024 | 01:07 AM
ipse dixit's Avatar
ipse dixit
They're all the same.
Only the badging on the rear deck is different.
Porsche is punking all of us. Charging us extra for "GTS" lettering and what-not. SMH.
#TryTheConfigurator
Old Jan 28, 2024 | 04:25 AM
alexb76's Avatar
alexb76
Thanks, so is the S/GTS turbos the same or different? Others think it's the same?!
Old Jan 28, 2024 | 04:27 AM
alexb76's Avatar
alexb76
Biggest bang for the buck! I believe 992 or 992.2 would be last ICE Porsche worth buying and keeping. So would like a long-term 911 to do it all. BUT, prices are so insane out of hands, specially the ridiculous options since my 997 times, I rather get the best technical platform for the money I can get.
Old Jan 28, 2024 | 05:27 AM
jhenson29's Avatar
jhenson29
Same turbos. GTS has more boost.
Old Jan 28, 2024 | 12:08 PM
someforumguy's Avatar
someforumguy
T is best. Dont waste money on anything more than that unless getting GT3/Turbo S.
