RAS cars are equipped with Lithium batteries?
#47
Premium Sponsor
>> The Porsche battery seems to be problematic and very expensive.
There are many pieces involved in this system - I don't think anyone has 'proven' the Li battery is the actual issue itself (though that's certainly possible). Problems have also been reported with the 'smart' battery management system, ConBox parasitic drain, software, among others. It's simplistic to say 'Li bad, AGM good', though clearly something is wrong..
Anyway as a little marketing chime, our Antigravity Battery can't and has never had that issue of not being able to wake up, so it isn't the chemisty of the battery that will cause the problem neccesarily, but rather the engineering or in their case over-engineering of a product.
#48
As demonstrated by Leno:
#49
I didn't see "AGM" on it anywhere and all the safety warnings present are those spoken of in the "Good to Know" manual.
#51
#52
Interesting - sure more will post MY24 examples soon. Without getting into the complexities of the lithium battery, somewhat disappointed from a weight standpoint. In isolation won’t make a difference, but overall with other options it all adds up.
#58
I wonder if there will be a retrofit to the AGM battery, if the lithium fails under warranty?
that would be a lot cheaper for porsche plus less of a pain in the *** if you have a problem.!
hopefully a retrofit to the AGM will be possible if you have a problem with the lithium after the warranty is up and you don’t wanna pop three grand for a new one
#60
My '23 T, non RAS car has the lithium battery installed as standard equipment. I haven't had any issues since my delivery in late June. However, with the reported battery problems and until there is a cost effective solution, I would highly recommend the use of a battery maintainer, especially if the vehicle isn't being driven on a regular basis.
I'm personally using a Noco Genius5 maintainer, it has a force mode feature that will allow charging if the battery goes below 1V.
Fullyield (09-21-2023)
