Paint rubbed/scaped off wheel edge, what do??
That's an easy fix for most wheel repair shops, and tire won't even need to come off. You can watch videos on Youtube of IG of them doing this simple repair.
Take it to an authorized body shop, it will need a respray most likely, not a big deal, but may cost a few thousand. They can fill in that piece on the rim also, some ******* parked next to you must have hit in when backing out.
Any mobile wheel repair guy can fix that. A body shop as well but it’ll be more expensive and not necessarily all that better.
Whatever you do don’t submit an insurance claim.
pkalhan (09-10-2023)
Insurance guy here. Unfortunately this type of carelessness by the other individual does happen. This is what insurance is for BUT would suggest going to an authorized shop to obtain a quote for the damage; appears to be in need of a re-spray and decide from there based upon your deductible and personal choice. Any residual damage; taillights functioning properly etc.? As well, agree wheel specific shops tend to not focus on this type of damage when it comes to the body and cosmetics so keep that in mind.
*Hopefully* that can be mostly repaired with some light sanding and air brushing. It might not be 100% but I would look into that before doing a full bumper respray and panel blend.
Staffie Guy (09-11-2023)
wheel fix will be ~ $125-$200 and the damage to the bumper, its hard to tell but if you have it fixed its probably 2-3 hours of labor to repair + cost to paint (which will vary wildly).
i ask what you hit because you might have other damage you can't see.
either way, you should take it to a couple porsche approved centers if you can and have them in your area to seek out the best place to get it fixed. really good places to get stuff like this fixed are not that common anymore, unforunatly.
funny thread how often the response is "easy wheel fix". To the OP, a good paint shop can fix that w/o re-spraying the entire wheel housing/quarter panel. They can do a small area spray and blend it. The more they spray away from the edge the more likely you will a small color mismatch. So, let them spray just the edge and blend an inch or less and it will be fine. To the comment it will be a few thousands...yeah, if you respray the entire rear end for no reason. Small blemishes happen all the time and good paint shops know how to make them go away without respraying the entire car. I had mine fixed a few times simply from rock chips on the fenders (either because I did not have the fender PPF or the chip was just beyond it). Unpleasant and upsetting, but its life.
@Tobeit I've read many of your helpful posts previously but this one has me wondering. Everything I've read and most of the responses in this thread indicate that a full respray of the bumper is necessary because a blend will show, particularly because it's Gentian Blue a metallic paint. Can you elaborate pls? Thanks.
onedae (09-11-2023)
Aventurine is also a difficult color to match - look at mine and tell me if you can see anything that is not matching that would bother you? The painter may have to make a small sample and adjust as just going by the books does not always bring the exact match. My painter dialed it in and now I can add pieces that look like OEM. So, in short, if they can't match the paint well painting the entire bumper will make it actually worse as you can see the difference all around along the hard lines of where the bumper ends and chassis starts. Painting just the edge and blending you have a much better change nobody will ever notice.
![](https://cimg7.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_6076_1__4ece4857c282a564a2ac02a26a2af8ba38a6b5eb.jpeg)
![](https://cimg8.ibsrv.net/gimg/rennlist.com-vbulletin/1440x1080/7f214203_c938_4763_adbe_c99dc44ece1e_1__ba67fe77993383b2b5db43c8dc942da55a5dbe3a.jpg)
