PSE EXHAUST HELP
Question on PSE. I’m coming from a 718 BGTS 4.0 and can hear the exhaust open when rpms exceed ~3.8K in first, second and third, and slightly lower rpm if fourth or higher.
On the 992 with PSE (mine will be a GTS), anyone know what approx rpm they open with PDK? I’ll be adding the car graphic controller, but just curious.
With the original 2 diamond icon switch assy installed and PSE activated, I found only one of the diamond switches could be programmed. Thus, I went for a proper solution. After the switch assy swap out PSE switch works as designed and the diamond is programmable to another feature as desired. It wasn't about the icon, it was because of loss of operability.
Schwarz992C4S (08-26-2023)
Nein Eleven (08-26-2023)
