1k oil flush (do or don't)?
Old 04-24-2023, 05:42 PM
  #31
AdamIsAdam
AdamIsAdam's Avatar
Received 4,038 Likes on 1,749 Posts
Originally Posted by Drew46
That is actually not his conclusion. He concludes (around 11:45) that is it s NOT necessary in most cars - unless it is a Subaru.
Well, he says some cars it's good to change at 1k, like Subie as you said, And more importantly is the engineer right afterwards who reiterates that point. So for most cars, it's not a big deal, and to save the environment, an early break-in is not necessary. So if you use your Porsche like a daily driver, you'll probably fine to have your first change at 1 year or 10k. Especially if you don't tend to keep your cars for a long time. But what I heard is, bottom line, change the oil after around 1k break-in to reduce risk of failure.
Old 04-24-2023, 10:20 PM
  #32
TK42ONE
TK42ONE's Avatar
So why can't you just change the filter early since it is top mount and top off the oil if necessary?
FWIW I have before and will change this one every 5k as it makes me feel good.
Old 04-24-2023, 11:25 PM
  #33
eclou
eclou's Avatar
Received 1,228 Likes on 600 Posts
The goal is to avoid overloading the oil filter so it can continue to filter contaminants out of the circulating oil. The goal is to always have clean oil. You could accomplish that by 1)replacing the filter with a new one, 2)replacing the oil with new oil, or 3)both 1+2
Old 04-24-2023, 11:29 PM
  #34
SS22
SS22's Avatar
My plan is to go in around month 10 when I expect to have about 4-5k and get it covered as my first year’s service. Seems like a good compromise to me! 1k seems overkill and 10k may not be a great idea for long term (although Porsche seems fine with it).
Old 04-25-2023, 07:18 PM
  #35
Diablo Dude
Diablo Dude's Avatar
Received 2,247 Likes on 1,258 Posts
Originally Posted by doug_999
I think you are confusing "Universal Samples" with "Samples from your vehicle make and engine type"
Edit - actually, I might be wrong here.
But I'm going to ask to confirm
I already confirmed and that's why I posted this for everyone to consider.
Fullyield (04-26-2023)
Old 04-26-2023, 08:52 AM
  #36
ns4w
ns4w's Avatar
The included oil change is 1 year from the "in service" date. My car sat for 6 months before I got it. I never got a good explanation as to why. I asked my dealership to do an oil change based on the "born on" date when my car was built, and they agreed to do an oil change at the time of my choosing without fuss. I had them do it after break in.
Old 04-26-2023, 09:56 AM
  #37
eclou
eclou's Avatar
My service tech did it for me on the side for $150 when installing my lowering springs. Showed me how to access the oil filter and the PLASTIC oil plug
Old 04-26-2023, 12:35 PM
  #38
minn19
minn19's Avatar
If you think changing the engine oil at 1k helps for break in reasons then you should also change the diff/transmission fluids based on the same logic.
Much like the break in thread going right now though, it really won’t make a difference for the vast majority of owners. Almost all failures occur due to manufacturing defects and changing fluids obviously won’t stop that. If you are track rat, they change their fluids often anyway and it is a different conversation than how most owners use their cars.
doug_999 (04-27-2023)
Old 04-26-2023, 12:48 PM
  #39
eclou
eclou's Avatar
Originally Posted by minn19
If you think changing the engine oil at 1k helps for break in reasons then you should also change the diff/transmission fluids based on the same logic..
I think most people don't bc the service intervals for fluid change on those is much longer. But yes you are correct
Old 04-26-2023, 12:52 PM
  #40
minn19
minn19's Avatar
Agreed, plus cost obviously goes up, especially if done at the dealer.
Quick Reply: 1k oil flush (do or don't)?
