1k oil flush (do or don't)?
Probably the biggest risk is if some of that silicone makes its way into oil passages and potentially blocks something. Obviously, it doesn't happen too often or we would hear about it more, but for the cost of an oil change, it seems like money well spent. Depends on your risk tolerance I guess.
Is the oil changed after the factory stress test dyno run? Most likely, I guess.
I know many of us, myself included, do used oil analysis and I can confirm that silicone is higher in the first oil change. Blackstone commented on it in my first analysis, and said it was typical.
So the question becomes at what level of particulates or PQ or UC indices is acceptable? Because there's always going to be particles and metallurgical remnants ... that's sort of why there's a filter, I suppose.
This begs the question - if we obsess enough about these cars to do a 4 to 5 figure PPF on the car why wouldn't we spend < $100 on a break-in oil change? 10 quarts of Mobile 1 0W40 is $60 at Walmart plus the Mahle oil cartridge
Well, my Blackstone report at 1,400 miles said:
"We expect to find extra silicon during the break-in stage; it's
just from harmless sealers/lubes used at the factory. It should wash out over the next few oil changes."
The number was 10 as compared to their universal averages number of 5.
For comparison, I pulled one of my reports from my GT350. The universal average for that car is 12. On my SECOND oil change at 2,700 miles (dealer did first one at 950 miles so I did not get an oil sample) the silicon was 21, then 4 subsequent oil changes had silicon numbers of 11, 8, 8, 8. (The 11 being the 3rd oil change, then all 8's.)
So by that logic, why not just change the oil every 1k.
If a little is good, then a lot more should be better, no?
At some point there needs to be a little sanity in all of this. PPF, oil changes, break-ins, etc.
Not to mention that some of us aren’t gonna get oil at Walmart and change it ourselves. So at minimum it’s gonna cost a few hundred to have someone do it. I wouldn’t wanna throw a few hundred dollars down the drain on anything unnecessary and this is no different. If Porsche recommended this, I would by all means do it.
One note about Blackstone Labs' reference data that they call "Universal Averages"
You have to ask them how many "samples" they've accumulated in their data-base.
I called them up in regards to 992 GT3's and 781 GT4's for the 4.0 liter engine and it was such a small sample size (total of 63 samples for both as of 2/13/2023) that it really doesnt carry any significance at this point.
For now, it's kind of a "take it with a grain of salt" type of data. You might be happy to have the data, but it's just not reliable data yet.
Of course, they need more customers to send in their oil samples so that their data-base grows.
It's a "chicken" or "egg" kind of thing.
AdamIsAdam (04-24-2023)
But yes, you can change your oil too often - and that just harms the enviornment.
BUT..... back to the point of this whole thread (the 17th one on break-in). Times ARE different. In the old days, engines and differentials shed metal like cray cray - and you broke the engine in VERY differently than you did today. As noted on one of the posts above, most top notch engine builders a) Still recommend an early oil change and b) do not recommend a 2,000 mile break-in. As my friend said (who is one of the top names in high performance Japanese cars - primarily Supras) - the tolerances these days are just so much tighter.....
Now I hope I remember to bring in my Blackstone container tomorrow for my 2nd oil change.
PS - in case you are curious, below are my numbers at one year and 3,400 miles. Pay close attention to the Aluminum, Iron, Copper, and Tin numbers compared to the Universal Averages....
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/782x946/blackstone992_84964ef3d619b02a3f1517468f7f337d02411702.jpg)
Edit - actually, I might be wrong here. Blackstone says
These averages are particular to your own vehicle, so you can compare your own engine’s average wear to national averages, which are what you see in the universal average column. Note that if you have two vehicles with the same engine, the unit/location averages will show average wear for both engines together. Your “fleet,” if you will.
But I'm going to ask to confirm
I don't even own a screwdriver.
When I was tracking my cars I had a ritual to do an oil change and bleed the brakes after every track weekend. That would be less than 1k miles if it was consecutive weekend. To me it was worth it. Same reason my wife buys our cat food that is $4 per can/per meal. Shes doesn't even spend that on my food
Yes, you should change your oil at about 1k miles or so to expel silicone. Straight from Corvette engineer's mouth:
https://youtu.be/zg6xa2caG-I?t=679
That is actually not his conclusion. He concludes (around 11:45) that is it s NOT necessary in most cars - unless it is a Subaru.
But this is Rennlist and we are all a tad insane right lol?
When I was tracking my cars I had a ritual to do an oil change and bleed the brakes after every track weekend. That would be less than 1k miles if it was consecutive weekend. To me it was worth it. Same reason my wife buys our cat food that is $4 per can/per meal. Shes doesn't even spend that on my food![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
And maybe tell your wife that you are her cat?
