FAL Necessity?
My dealer is telling me it’s a must have. True? Didn’t have one on my 17 C2S.
This topic has been beaten to death in multiple threads - I'm sure you will find a lot of opinions.
The easy answer is that some people need it to get in/out of their garage/driveways - obviously making it a necessity.
Then there are the people that get it because if you ever even need it one time during ownership - then you have it.
Of course many will argue that the front lip is replaceable for a couple hundred $$ so why spend $3k.
There is no right or wrong answer, it comes down to your situation, and view on how important it is for you to have, or not have that option.
Personally I ordered it on my 992 GTS, I figured its better to have it and not need it, than to need it and not have it.
I’m actually thinking of passing on this option,
catdog2 (04-15-2023)
Only necessary when you damage your front lip lol.
I have it and it’s beneficial in most cases but still scraped my lip a few times when I was not mindful of using it.
Either way you should be fine. I’ll say get it if you can.
I didn't get it on my C2, don't need it personally.
I did not get it and did not need it until I got the Carbonio license plate holder.
Contrary to what Carbonio says, it decreases front clearance by about a half inch-just enough for me to scrape the bottom of my license plate several times and I had to realign the holder each time.
Go Bruins (04-16-2023)
If you have no plan to lower the car, without FAL is totally livable. For people that plans to lower the car, FAL is a good option to have.
Targa 4 GTS without it and am not scraping at all. I have what I consider to be a normal sized curb, not particularly low profile, and approach on an angle - no problems. No issues with parking lot entrances or speed bumps either.
I asked the same question about 2 weeks ago before my C2 GTS locked. Consensus ? nope 50/50.
Went to add it and my sales exec said "don't get it" when I asked why he repeated "don't get it" have to think he said this for a reason.
Don't feel bad ... when I asked I got "use the search function" a few guys can be uppity.
Had FAL on my '2018 GT3 not on my 2016 GTS. I scraped the GTS on our relatively steep driveway on the day I took delivery. Did not have that problem with the GT3.
It really depends on your situation and where you drive. Adding it again on my next GTS.
