Lowered 992 picture thread
The following 2 users liked this post by Trini:
RolandT (07-19-2023),
tourenwagen (07-18-2023)
#65
1. OE suspension: SPASM
2. lowered appox. 20mm front and 25mm rear
3. wheel offsets: ET 38/57
4. OE wheel size with OE tires
5. lowering kit: Techart HAS
The following 4 users liked this post by Wilder:
Vernin (03-06-2024)
The following 7 users liked this post by DT992:
AlterZgo (07-20-2023),
Andy2021 (02-20-2024),
cwbrown (07-21-2023),
Jeahbladejeah (07-20-2023),
laurenxesq (01-03-2024),
and 2 others liked this post.
#69
Premium Sponsor
The following 6 users liked this post by andreas722:
AlterZgo (07-21-2023),
DT992 (07-22-2023),
Vernin (03-06-2024),
and 1 others liked this post.
#71
#72
Fronts around 678 mm to fender and 718mm rears.
I think this might be a bit too low and may likely raise it by another 7-8mm.
Are you guys scraping at all? The plastic flaps in front of the front tires are worn out. Only 2.5” of clearance there! Other spots I’ve got around 4-4.5” of clearance at the front.
1stgear (04-11-2024)
#73
#74
Hi Everyone,
Was wanting to get a rough idea what the going rate is when it comes to lowering your cars ($1000 to $2000?). Is one application (HAS kit) at a lower installation price point than coilovers? I heard that a coilover install is easier than lowering springs or HAS kit install because you take out the OEM unit and just replace it with the coilover. Not sure how true that is.
Any info that you guys can provide would be appreciated.
#75
Hi Everyone,
pkalhan (01-02-2024)
