Lowered 992 picture thread
The following 6 users liked this post by Tobeit:
AlterZgo (12-19-2022),
Jeff Whitten (11-19-2023),
Moosedoc (07-20-2023),
philghill (07-11-2023),
pkalhan (07-12-2023),
and 1 others liked this post.
The following 11 users liked this post by philghill:
AlterZgo (07-11-2023),
ash_schwin (07-11-2023),
Chalk992911S (07-11-2023),
J Irwan (04-24-2024),
Jeahbladejeah (07-11-2023),
and 6 others liked this post.
@philghill Gorgeous GTS. I really wanted a Aventurine.
20/21 Vossen’s with KW HAS, Tarett Engineering camber plates…..255/35/20 and 315/30/21 GY SuperSportR’s
Camber at -2.5 rear and -2.0 front.
Lowered from SPASM - 7/8” front and -1/2” rear on Bilstein EVO coil overs. Handling and ride quality in normal, sport and sport+ all improved over stock. Don’t get me wrong, even stock, the car never felt like it had great ride quality, but w/ Bilstein EVOs, it doesn’t feel like a lowered car as it seems to have pretty much the same suspension travel even when going over larger dips and bumps.
However, the red and the classics look so amazing. gorgeous.
Gentleman, this thread would be far more useful if everyone posted the following (in order of importance):
1. what OE suspension - non-PASM, PASM, or SPASM
2. how many mm or inches they lowered their car by
3. wheel offsets
4. size of wheels and tires
5. brand of lowering kit
3. wheel offsets
The following 5 users liked this post by Wilder:
Jeff Whitten (07-11-2023),
Mikey K (07-15-2023),
Vernin (03-06-2024),
Vitruvian_man (09-11-2024)
Vernin (03-06-2024)
Vernin (03-06-2024)
Here's my lowering journey...
Aug 15, 2021 - Stock 992S w/ stock SPASM and stock 20/21" Carrera Classics, NO spacers measured from floor to edge of fender w/ full tank of extended tank of gas:
January 9, 2022 - 3 days after lowering w/ Bilstein EVO coilovers, stock Carrera Classic rims and tires w/ 15mm F and 12mm R spacers, measurements from floor to edge of fender with 3/4 tank of gas:
2. how many mm or inches they lowered their car by: F -7/8" (-22 mm), R -5/8" (-16mm)
3. wheel offsets: Stock Carrera Classic rims w/ 15mm FRONT spacers and *12mm REAR spacers so effective offsets: F +35, R +55 (*I eventually switched to 15mm spacers all around which is best IMO)
4. size of wheels and tires: Stock Carrera Classic rims F 20x8.5" w/ 245/35/20 and R 21x11.5" w/ 305-3021 Pirelli PZ4
5. brand of lowering kit: Bilstein EVO coilovers
July 20, 2023 - 1 1/2 years after lowering and 8,600 miles on Bilstein EVO colivers + new BBS FI-Rs and slightly wider/taller tires measured from floor to edge of fender w/ 3/4 tank of gas:
2. how many mm or inches they lowered their car by: F -3/4" (-22 mm), R -7/8" (-19 mm) *note: sometime between first measurement and this 2nd measurement 1.5 yrs later, I raised front spring perches by 1/4".
3. wheel offsets: BBS FI-Rs w/ 7mm spacers F and R so effective offsets: F +41, R +53
4. size of wheels and tires: BBS FI-Rs F 20x9" w/ 255/35/20 and R 21x11.5" w/ 315-30-21 Michelin PS4S (note: tires are slightly wider and taller than stock: F stock 26.8" tall vs. 27" tall (.2" or 5mm taller) for 255-35-20 tires, R stock 28.2" tall vs. 28.5" tall (.3" or 7.5mm taller) for 315-30-21 tires)
5. brand of lowering kit: Bilstein EVO coilovers (settled after 1.5 years and 8,600 miles)
How much did the suspension settle over 1.5 yrs and 8,600 miles on Bilstein EVO coilovers?
Front: 27 5/8"
Rear: 29 1/4"
Rear: 29 1/4"
Front: 26 3/4"
Rear: 28 5/8"
1. what OE suspension - non-PASM, PASM, or SPASM: SPASMRear: 28 5/8"
Front: 26 7/8"
Rear: 28 3/8"
1. what OE suspension - non-PASM, PASM, or SPASM: SPASMRear: 28 3/8"
Front suspension settled .3" (8mm) - Calculations: 26 7/8" initial lowering + 1/4" raising + .2" taller 255/35/20 tire = 27.2" vs. actual height of 26 7/8"
Rear suspension settled .5" (13mm) - Calculations: 28 5/8 initial lowering + .3" taller 315/30/21 tire = 28.9" vs. actual height of 28 3/8"
The following 13 users liked this post by AlterZgo:
Aescobar102 (06-23-2024),
dixonk (07-11-2023),
ErikinSC (09-08-2024),
Jeff Whitten (07-14-2023),
and 8 others liked this post.
Vernin (03-06-2024)
On the otherhand, if your engine blows up or your PCM dies, they're not going to void that warranty simply b/c your car is lowered.
