Lowered 992 picture thread
The following 10 users liked this post by peterjp:
AlterZgo (07-11-2023),
ErikinSC (08-26-2024),
evanbahr (01-03-2024),
Jeahbladejeah (07-11-2023),
KLOC (07-21-2023),
and 5 others liked this post.
#32
@timothymoffat thanks! Super happy with how it turned out.
@Wilder here is info on my GTS:
1. Before lowering: Standard GTS suspension (which I believe is non-PASM)
2. Lowered approx. 1 inch front and rear (reminder that standard GTS comes 10mm lower than a Base/S with PASM, at least that is what I remember)
3. Didn't change offsets (I have stock Carrera S wheels on my GTS, painted)
4. Standard Carrera S wheels 20" and 21". Still have original issue Goodyear tires, 245/35-20 and 305/30-21
5. KW Height Adjustable Spring Kit, around $1,500.
The following 11 users liked this post by vic55:
Acropora8 (01-13-2024),
AlterZgo (07-12-2023),
dhirm5 (07-18-2023),
Hulley (07-21-2023),
Jeff Whitten (07-14-2023),
and 6 others liked this post.
#35
Vernin (03-06-2024)
#36
@Wilder Thanks very much!
@vic55 Every time I see your car it is just awesome. That color is very cool and it looks so good lowered--occasionally I think maybe I should have gotten that color too. And thank you for your prior posts on lowering, I used them a lot in figuring out what I was going to do on mine.
#37
@philghill @vic55 @AlterZgo you've convinced me to wind the front down a little more... your cars looks great!
The following 11 users liked this post by tourenwagen:
bayarea_sb911GTS (02-19-2024),
Ed99 (01-13-2024),
Jeahbladejeah (07-12-2023),
Jeff Whitten (11-19-2023),
The following 2 users liked this post by philghill:
tourenwagen (07-12-2023),
Vernin (03-06-2024)
#39
The following 4 users liked this post by AlterZgo:
#40
Techart HAS - about 25mm front, 20mm rear, stock tire/rim width but +39 and +56 offsets.
The following 6 users liked this post by Tobeit:
Ed99 (01-13-2024),
pkalhan (07-12-2023),
Vernin (03-06-2024),
and 1 others liked this post.
#41
Thank you! Got custom wheels made in stock sizes with ET38 and ET57 not knowing what they would look like. I guess I do now. I will be lowering 10mm rear and 15mm front on SPASM (so already 10mm lower than PASM), though it seems your car has SPASM too because I'm expecting to be a tad higher than you. Also on Techart HAS and with GT3 skirts.
#42
The following 7 users liked this post by Tobeit:
AlterZgo (07-13-2023),
Canuck9 (07-12-2023),
philghill (07-13-2023),
and 2 others liked this post.
#43
@Tobeit thanks for the extra pics. Now I really know what it's going to look like. Absolutely love the stance. It's exactly what I wanted. Picking up the car tomorrow or Friday with new wheels, side skirts, ride height and alignment. Can't wait!
The following 3 users liked this post by Wilder:
#44
#45
At this right height the OEM camber adjustment was just enough to get it right on the edge of the spec. So you will run at the end of the OEM camber spectrum, which makes it look pretty nice. Also, with the Gt3 side skirts I need to drive on 2x4 to get even a low profile Jack under the car. Not a big issue just something you need to be aware of. Other than that, I like the feel of the techart kit. A little stiffer but entirely good for every day use.
