First Night Drive - Blinded by the (Interior) Light
I did my first night drive, and was surprised by the brightness of the (a) instrument panel, (b) PCM screen, (c) overhead light, and (d) overhead airbag warnings.
I did some searching and found some threads on (c) and (d) -- I ordered some tinted vinyl from Amazon ( ) to hopefully mitigate those items.
In terms of the instrument panel and PCM screen, I went through the menus and tried to dim as much as possible, but it didn't seem to make an appreciable difference? Any thoughts/experience to share? I may very well be missing something simple. I was looking for the typical interior brightness adjustment dial/****, to no avail.....
Yeah, the screens don't get as dim as I'd like either. IIRC there are two screen brightness settings (for center screen and instrument cluster) and then an ambient lighting brightness (which doesn't affect the overhead or auxiliary lights - only the colored ambient light strips). Setting the two screen brightnesses to their minimum helps, but doesn't dim things quite enough.
I've been meaning to get a similar vinyl sheet and pop the overhead panel out to dim the lights up there, thanks for posting and prompting me to go ahead and order them.
sharknose (11-10-2022)
Received 2,721 Likes
Maybe I'm just being an old man - pining for the days when you could dim the lights way down with the simple twist of a **** (or Saab's famous "Night Panel" button that would turn off all interior lights except for the speedometer). It just seems much easier to drive at night with less ambient light in the cockpit.
Button “A” in the picture pressed in for a couple of seconds turns the PCM screen off. Really, the Owners Manual is helpful.
The following 6 users liked this post by icanthelpit:
aggie57 (11-09-2022),
dhirm5 (11-09-2022),
JDeRose (11-09-2022),
passat774 (11-08-2022),
Smirnoff67 (11-08-2022),
and 1 others liked this post.
I took other people’s idea and when I hard wired the radar detector, I put two strips of dark tint for the airbag lights and the area light from the back side. It’s much better now.
I have to admit my olderE92 BMW redish interior lighting is better than the 992. Enough to see stuff, but not as much glare as the white coming from overhead and the rather bright instrument cluster and PCM screen. Interesting is that the optional ambient lighting isn't quite as interesting as my wife's G20 ambient lighting. Of course, chassis dynamics and power are a quantum leap over the Bimmers.
