That would be great. The diamond on the steering wheel has worked fine for me though.
this solution works okay but is not great. Still just opens the homelink screen and then you need to press the screen again, Issue with that, when backing out of garage the rear view camera is shown and does not let the homelink screen come up. So, you need to manually close the rear view, press the diamond, then press the screen. Other option is to wait until rearview camera closes by itself...but that takes forever and requires to drive forward some.
They may have removed it. Mine is a 22 and it’s a digital clock like a Casio watch display. But I wouldn’t fret if it’s not there. There is 2 other clock displays staring at you if that’s not there lol.
Unless you want to use as a stop watch, the Sport Chrono Dial seems to be useless. Even the digital clock in the middle (at least in my C2) is too small to be functional. So, if $1k is not that material to OP, I would recommend the optional clock. At least it is functional and looks good.
An interesting note about the analog clock: It resets to 12 when the car is off, and sets itself to the correct time when you turn the car back on. I always assumed it was a full analog/mech clock but it's grabbing time data digitally from the car.
From the config photo it seems like that digital clock in the middle is not there anymore?
It just opens the garage door on mine. I have never seen the home link screen. I turn the home link location off. The diamond then just becomes an opener. Works about 3 houses away.
Although on the interior picture there does seem to be that small digital clock in the middle. Not sure why it's different to the actual option picture?
Mhm...you think turning the home link location off changes the behavior and the diamond directly operates the garage? I will try that but believe others have found before that opening the homelink screen was unavoidable. I have old PCM.
I think it may. When I first got the car I found the location based home link screen to be annoying. I turned that off right away. I then programmed the diamond and it has simply opened my garage door without doing anything on the PCM.
