Trickle Charge Options
Old Aug 18, 2022 | 02:45 PM
d6veteran's Avatar
d6veteran
Default Trickle Charge Options
We have a 992, 718 GTS and 718 Spyder that rotate through storage for up to 2-3 weeks. All of them are US cars, and none of them have the smoking package. What is my best option for charging while in storage? The charge mat + alligator clips right to the battery?
Thanks.
Old Aug 18, 2022 | 03:19 PM
Richard_Wallace's Avatar
Richard_Wallace
All of them will have a cigarette 9v port (the 992 is passenger side footwell).
I think the best way though is to get a permanent pigtail (direct to battery) - easy quick connector (you can get a charger from Ctek on Amazon, and get 2 Ctek pigtails (one comes with the CTEK. Make sure you get an AGM (or lithium charger - depending on what you have) - assume all of yours is AGM battery type.
All my cars have the pigtail attached, makes it easy to connect/disconnect the charger.
Old Aug 18, 2022 | 03:24 PM
d6veteran's Avatar
d6veteran
Originally Posted by Richard_Wallace
All of them will have a cigarette 9v port (the 992 is passenger side drivers footwell).
Thanks for the reply Richard.
  • I'll check the manuals - it sounds like there is an aux 9v port in the cars despite not having the smoking package?
Old Aug 18, 2022 | 03:34 PM
d6veteran's Avatar
d6veteran
This looks like it supports AMG batteries. There are so many options it is hard to tell.
Amazon Amazon
Old Aug 18, 2022 | 06:18 PM
Richard_Wallace
https://www.amazon.com/CTEK-Battery-.../dp/B082BXK6DK
Yes you will have a 9V even without the smoking package.
Ok here you go this is the AGM charger you will need from CTEK. I use this particular one on my 2018 GT3 Touring, and 2 other cars.
My 992 has Rear Axel Steering which means it has a LiPo battery - so I use the Lipo specific charger on that one and my 720s.
Here is the proper link from Amazon on the charger for AGM type batteries.
Amazon Amazon
This one comes with One Pigtail in the box.
I believe you said you have 3 cars with AGM batteries.
You will want to order 2 of these extra pigtails:
Amazon Amazon
If you need extra long connector (depending on how far the charger is from a plug. You can buy this which goes between the charger and the pigtail. (you may have the power close to where you park, so probably do not need this, but just in case, thought I would add it.)
Amazon Amazon
There are easy instructions on the forum on how to hook up the pigtail to the 992 - takes about 5 minutes direct to battery. Actually any car should be about 5 minutes to do, and once you do it, you never have to do it again.
Old Aug 18, 2022 | 06:24 PM
tourenwagen's Avatar
tourenwagen
Old Aug 18, 2022 | 07:52 PM
d6veteran's Avatar
d6veteran
Originally Posted by tourenwagen
lol - meaning I am going to have more questions?
Old Aug 18, 2022 | 07:53 PM
d6veteran's Avatar
d6veteran
Thanks for the links Richard!
Old Aug 18, 2022 | 08:57 PM
siberian's Avatar
siberian
CTEK with connected pigtails for quick connect/disconnect. As with AGM and especially LiFePO4 batteries do not leave the batteries permanently connected. These batteries need to be able to discharge and then be recharged and as Richard mentioned get the specific charger for your type of battery.
I've got 3 chargers. A regular wet battery one for my Touareg and Olga (my skid steer), a CTEK AGM for the wife's Macan and a LiFePO4 for my 992. The right tool for the right job
siberian
Old Aug 18, 2022 | 09:48 PM
PCA1983's Avatar
PCA1983
I think you mean AGM batteries.
If you research you will see these are not trickle chargers. They are battery tenders.
Yes CTEK is the best. CTEK makes the Porsche Brand battery tenders.
I have one I've used for 6 years on 4 different 2015+ Porsches. Great battery tender!
i would not use any other battery tender on my Porsche AGM batteries!
Old Aug 18, 2022 | 10:07 PM
tourenwagen
just a joke, this time of year always brings out the battery charging posts
Old Aug 18, 2022 | 10:26 PM
PHX's Avatar
PHX
Totally agree with @Richard_Wallace about the brand, method, and connectivity. Works like a charm. I do have a lowly AGM battery though and can't attest to the LiION ones.
I have used CTEK for years on all sorts of domestic vehicles without fail and even when the power fails, the whole home generator kicks on, then power returns and the CTEK keeps on kicking like a champ doing it's business.
Old Aug 18, 2022 | 10:51 PM
GTS2022's Avatar
GTS2022
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
https://www.amazon.com/CTEK-56-382-C...e%2C141&sr=1-4
https://www.amazon.com/CTEK-56-304-C...e%2C141&sr=1-5
Thank you for the information. Does it also work with light weight battery. I have 992 with rear wheel steer that comes with light weight battery.
Old Aug 19, 2022 | 02:41 AM
siberian's Avatar
siberian
Light weight? You mean LiFePO4? Yes CTEK makes one for those, I have one for my 992.
siberian
Old Aug 19, 2022 | 07:58 AM
Richard_Wallace
For my 992 with LiPo you would want this specific CTEK charger. They do make one 7002 (IIRC) which you can switch modes and do either AGM or LiPo. But this one is specific for just the LiPo.
Amazon Amazon
