Factory Aerokit wing
Got a question for those folks that got their 992's with the factory Aerokit spoiler. Do you have the option to raise the spoiler to service the rear bumper with the button for the spoiler in the "car" option in the PCM?
I installed an aftermarket fixed spoiler and had a dealer code out the raising of the spoiler, but they all together coded out the option in the PCM under "car" profiles. The SA said I would have to come and code the spoiler in/out every time if I had to service the rear bumper, taillights, and all the other things under the spoiler. Sound right?
Guess I would only need it once to change out the exhaust cover, but I just think it sucks not having the feature for other possible upgrades. Don't want to have to go to the dealer every time to code the spoiler function back in. Possible upgrades like an exhaust, plenum, or maybe just minor engine work that doesn't need to be taken to the dealer to do.
Do you have the aerokit and don't have the spoiler button in your PCM?
I’ve read a couple of anecdotes. One version is you have to code out the error codes when you remove the movable rear wing because you are removing the motor mechanism and disconnecting the third brake light in the wing so the car will throw an error code unless you code it out.
I’ve also read that you can just code the raising of the rear spoiler to a speed the car will never reach… like 200 mph. That way your aftermarket rear wing will never raise at speed, yet you still have the option of manually raising the wing to access stuff like the rear bumper bolts.
https://rennlist.com/forums/992/1206...l#post18115099
Also see rnlst_log's post 346 where he provides more details on what to change in these tables.
dbtran (08-02-2022)
