Note that 'Partial Load' is anything under 600lbs of passengers + cargo. So you would usually be in partial load condition.
Comfort pressures of 29/32 psi for summer tires (32/35 psi for winter tires) should not be used for sustained speeds above 165mph.
Normal and comfort pressures are listed in the owners manual. They are hard to find but look under "technical information."
My car was delivered with 45 in the front and 50 in the rear! The steering was twitchy, the suspension was bone jarring, and the tires howlled. I set them to 30/33 and now it all feels right.
Any advice from new GTS owners on their preferred tire pressures?
My 4 GTS has the center lock wheels with Pirelli P-Zero.
Dealership set the pressures at 38/44 and refused to lower them a bit prior to delivery.
44 psi at the rear seems too high and harsh.
What should I do in the PCM to lock that in as my normal?
Just an opinion but 36 f x 40 r cold tire pressures are still very high as they will creep to 39x44 under normal driving.
If you are not driving with bar bells in the front seat and frunk try the partial load comfort pressure and see if you like the way it rides. Just an opinion. It’s your car.
First, I run the summer tires year around so the basic rule I follow is I want my tires to be around 36F and 40R when they are HOT. So the cold temps vary depending on the time of the year. I have come to this "recommendation" after driving my car on the various roads around TN and NC.
I have tried lower and higher pressures but found these seem to work the best for ME, so you probably should try the various recommendations and see what suits you the best. Good luck.
