992 C2 Start/Stop Programming
New owner here - need help programming the start/stop always "off" - is it doable in the individual setting? Cannot locate info on how - played in the PCM - still unsure. Thanks.
There is a thread going on in the Turbo S forum re this issue.
I am also struggling as it appears some people are able to modifying each drive mode and disable this but others (like myself) are not so it comes back on every drive. Perhaps model specific, build date or county of origin makes this different? Or perhaps I just cant figure it out?
https://rennlist.com/forums/992-turb...n-disable.html
Can’t be permanently disabled through the PCM. It is always on with restart in normal drive mode.
I programmed a diamond switch to easily turn it off when I start the car. It is also disabled in sport mode, sport plus, and if you program it that way in individual mode. But any of these require an driver action at starting the car too.
M3Inline6 (04-28-2022)
I have done the same, but it seems a few of the 992 Turbo people are saying they can modify normal mode in order to keep it permanently off.
Thanks - that's what I thought. Too bad. My Ford Explorer makes it easy - there is a button on the console with one touch it's off for the ride. Yes you do it with each start but no deep- dive into any menu.
I programed the diamond on the steering wheel. But since I never drive in Normal mode, I changed that to my garage door opener. Normal mode makes for a less than satisfying experience.
M-Engineering can permanently disable it with their tune software. That, and the cold start, as well. Those 2 things USED TO drive me bonkers every time I started the car.
Tupper (04-30-2022)
I hate the start/stop feature. It’s annoying and dangerous. With rental cars, I don’t give a s&*t about the car and sometimes leave it on. I’ll be at an intersection ready to merge and that engine start up takes enough time that I can’t make a clean merge if another car is coming. You might think I’m too aggressive but I rent cars in European countries where you have to drive aggressively to get around. Also, I don’t think it’s good for turbos to be shutting on and off all the time, especially high performance turbos
Schorsch (04-30-2022)
It's more like 6-10 seconds, actually. Sort of surprising. Engineering Explained video: https://youtu.be/dFImHhNwbJo
