Auto Start / Stop Function-Disable
Hi everyone- just took delivery of a MY 2022 992 Turbo and was wondering if there is a way to permanently disable the auto start/stop function? I found the M-Engineering kit tuning kit allows for this as one of the features but not as a standalone re-programming. Curious to see if there are any other options. Thanks
A few choices, if you drive in sport or sport plus (via turning the ****) that cancels the start/stop feature, if you want to call it a "feature" , you can also program the Ind/Personal **** position and turn the start/stop funtion off. Personally I only drive in sport or sport plus so for me it's not an issue, the car is boring in the "normal" mode JMO I have to see if it can be turned off via the Porsche service software, but most likely it can not, and yes it can be programmed out as well
Turn the **** as soon as you start the car. Sport mode is the real "normal" mode. I turn it without even thinking now.
The following 3 users liked this post by rk-d:
I just need a review.....
Does Normal Mode soften or relax the suspension (as opposed to sport or sportplus) ?
Sport Mode stiffens it ?
add PDCC to do what ?
Porsche Driving Modes Explained
- Normal: The 'Normal' mode is the default driving mode that's ideal for commuting or more comfortable cruising. When selected, the throttle response is a little slower, and shifts happen sooner, the suspension is softer, sport exhaust valves will close, and start/stop stays active.
- SPORT: The 'SPORT' mode is your perfect driving mode for more spirited drives through backroads or canyon passes. When selected, throttle response and shifts are sharper, the suspension is stiffer, sport exhaust valves will open, and dynamic engine mounts will engage.
- SPORT+: The 'SPORT+' mode is your go-to driving mode for track days or simply experiencing all of the performance your Porsche has to offer. The throttle response is instantaneous, shifts are lightning fast, and the overall steering and suspension feel is tight and responsive.
- Individual: The 'Individual' mode is for those who want to customize the various settings to their liking. If you want the 'Normal' soft suspension without losing the sharp shifts and throttle response you get with 'SPORT+,' or you want all of the comfortable 'Normal' settings but with the 'SPORT' exhaust noise, the 'Individual' setting is for you.
- WET: The 'WET' driving mode, as the name implies, adjusts the vehicle's settings to help you drive better in the rain and adverse conditions.
SPORT Response Button
In addition to choosing your preferred driving mode, the mode selector **** on the steering wheel features a button in the middle that engages 'SPORT Response.' This feature primes the engine and transmission for a surge of power and responsiveness for 20 seconds. Press this button for maximum performance if you need to overtake someone and want a little boost.Last edited by hcvone; 04-26-2022 at 01:47 PM.
The following 5 users liked this post by hcvone:
daveo4porsche (04-28-2022),
NigelPlays (05-18-2022),
Patton250 (04-29-2022),
RD16RR (04-26-2022),
Steve 96C4S (05-10-2022)
TECHNOLOGY EXPLAINED: PORSCHE DYNAMIC CHASSIS CONTROL
- News
- Josh Barnett
- 0 comments
In order to achieve a greater equilibrium between all four contact patches, Porsche has developed an electrohydraulic antiroll bar system, resulting in more responsive handling when driving your 911 on the limit.
Rather than using normal links between the dampers and the antiroll bar, PDCC uses hydraulically actuated cylinders to mechanically alter the load on both the front and rear antiroll bars.
Sensors connected to each damper measure the movement under both bump and rebound. These measurements are then used to determine how to load both antiroll bars.
At each corner of the car, the cylinders move in the opposite direction to the dampers (pushing the antiroll bar under bump, and pulling during rebound). This optimises the camber of each wheel, as well as ensuring that the ideal amount of load is transferred from wheel to wheel when turning the corner.
All of this results in a more direct turn in, while ensuring that the car feels more stable during cornering.
As part of our ‘Technology explained’ series, you can also find out how Porsche Carbon Ceramic Brakesimprove your stopping power, why Porsche Active Suspension Management improves stability, and what Porsche Traction Management really does.
- Share on Facebook
- Share Twitter
- Plus one on Google Plus
- Save on Stumble Upon
- Pin on Pintrest
- Share on Reddit
COMMENTS (0)
RD16RR (04-26-2022)
what control (if any) of the front and rear spoilers do you have in sport+ ?
The 992 Porsche 911 Turbo S's Active Aero Includes New Airbrake, Dynamic Cooling
With great power comes great aerodynamic responsibility.
Greg FinkWriterThe ManufacturerPhotographerApr 15, 2020
[img]data:image/svg+xml,%3csvg fill='none' height='24' viewBox='0 0 24 24' width='24' xmlns='http://www.w3.org/2000/svg'%3e%3cpath clip-rule='evenodd' d='m8 2h12c1.1 0 2 .9 2 2v12c0 1.1-.9 2-2 2h-12c-1.1 0-2-.9-2-2v-12c0-1.1.9-2 2-2zm12 14v-12h-12v12zm-8.5-4.33 1.69 2.26 2.48-3.1 3.33 4.17h-10zm-9.5 8.33v-14h2v14h14v2h-14c-1.1 0-2-.9-2-2z' fill='%23fff' fill-rule='evenodd'/%3e%3c/svg%3e[/img]SEE ALL 54 PHOTOSPorsche knows that horsepower is only one part of the larger sports car equation. That's why the German brand equips the 2021 911 Turbo S with a bevy of advanced active aerodynamic features to simultaneously tame that power while helping it perform at its best. Dubbed Porsche Active Aerodynamics, the setup offers eight different aero configurations that help the 640-horsepower 911 more effectively slice through the air. Porsche didn't hold back, either. Read on to learn about the wildest features that make up the Turbo S's Porsche Active Aerodynamics kit:
Rear Wing
Like its predecessor, the 992-series Turbo S boasts a decklid spoiler that automatically deploys a secondary wing as conditions permit. Weighing approximately one pound less than the unit used by the prior 911 Turbo, the new car's wing offers two new positions of deployment, alongside the previously available speed and performance position: Performance II and Wet.The former assists at speeds exceeding 160 miles per hour, as the wing's angle reduces drag and limits the load on the rear tires. Meanwhile, the Wet function raises the wing without tilting it to increase rear-end downforce and improve vehicle stability.
Front Spoiler
The latest 911 Turbo S once again sports a retractable front spoiler. In its Speed position, the outer areas of the spoiler extend, while in its Performance setting, the spoiler's central piece emerges, as well. (There's also a standard position that keeps all three pieces hidden away.) Thanks to its more compact pneumatic actuator module, which controls the spoiler's position, the new Turbo S features an additional 0.1 cubic foot of space in its frunk relative to its forebear.[img]data:image/svg+xml,%3csvg fill='none' height='24' viewBox='0 0 24 24' width='24' xmlns='http://www.w3.org/2000/svg'%3e%3cpath clip-rule='evenodd' d='m8 2h12c1.1 0 2 .9 2 2v12c0 1.1-.9 2-2 2h-12c-1.1 0-2-.9-2-2v-12c0-1.1.9-2 2-2zm12 14v-12h-12v12zm-8.5-4.33 1.69 2.26 2.48-3.1 3.33 4.17h-10zm-9.5 8.33v-14h2v14h14v2h-14c-1.1 0-2-.9-2-2z' fill='%23fff' fill-rule='evenodd'/%3e%3c/svg%3e[/img]SEE ALL 54 PHOTOS
Airbrake
Yes, the 911 Turbo S includes a freaking air brake function that places both the front spoiler and rear wing in the most aggressive Performance positions when braking at high speed. Given its most aggressive aero settings produce as much as 375 pounds of downforce, the 911 Turbo S's Airbrake function ought to prove beneficial to track junkies looking to brake as late as possible.[img]data:image/svg+xml,%3csvg xmlns='http://www.w3.org/2000/svg' width='24' height='24' viewBox='0 0 24 24'%3e%3cpath d='M12 2C6.47 2 2 6.47 2 12s4.47 10 10 10 10-4.47 10-10S17.53 2 12 2zm5 13.59L15.59 17 12 13.41 8.41 17 7 15.59 10.59 12 7 8.41 8.41 7 12 10.59 15.59 7 17 8.41 13.41 12 17 15.59z'/%3e%3cpath d='M0 0h24v24H0z' fill='none'/%3e%3c/svg%3e[/img]
[img]data:image/svg+xml,%3csvg xmlns='http://www.w3.org/2000/svg' width='24' height='24' viewBox='0 0 24 24'%3e%3cpath fill='%23ffffff' d='M16.5 12c0-1.77-1.02-3.29-2.5-4.03v2.21l2.45 2.45c.03-.2.05-.41.05-.63zm2.5 0c0 .94-.2 1.82-.54 2.64l1.51 1.51C20.63 14.91 21 13.5 21 12c0-4.28-2.99-7.86-7-8.77v2.06c2.89.86 5 3.54 5 6.71zM4.27 3L3 4.27 7.73 9H3v6h4l5 5v-6.73l4.25 4.25c-.67.52-1.42.93-2.25 1.18v2.06c1.38-.31 2.63-.95 3.69-1.81L19.73 21 21 19.73l-9-9L4.27 3zM12 4L9.91 6.09 12 8.18V4z'/%3e%3cpath d='M0 0h24v24H0z' fill='none'/%3e%3c/svg%3e[/img]CLICK TO UNMUTE
[img]data:image/svg+xml,%3csvg height='24' viewBox='0 0 24 24' width='24' xmlns='http://www.w3.org/2000/svg'%3e%3cpath d='m6 19h4v-14h-4zm8-14v14h4v-14z' fill='%23fff'/%3e%3cpath d='m0 0h24v24h-24z' fill='none'/%3e%3c/svg%3e[/img][img]data:image/svg+xml,%3csvg xmlns='http://www.w3.org/2000/svg' width='24' height='24' viewBox='0 0 24 24'%3e%3cpath fill='white' d='M7 9v6h4l5 5V4l-5 5H7z'/%3e%3cpath fill='none' d='M0 0h24v24H0z'/%3e%3c/svg%3e[/img]
[img]data:image/svg+xml,%3csvg xmlns='http://www.w3.org/2000/svg' width='24' height='24' viewBox='0 0 24 24'%3e%3cpath fill='none' d='M0 0h24v24H0z'/%3e%3cpath fill='white' d='M3 5v4h2V5h4V3H5c-1.1 0-2 .9-2 2zm2 10H3v4c0 1.1.9 2 2 2h4v-2H5v-4zm14 4h-4v2h4c1.1 0 2-.9 2-2v-4h-2v4zm0-16h-4v2h4v4h2V5c0-1.1-.9-2-2-2z'/%3e%3c/svg%3e[/img]
[img]data:image/svg+xml,%3csvg height='24' viewBox='0 0 24 24' width='24' xmlns='http://www.w3.org/2000/svg'%3e%3cpath d='m15.41 16.59-4.58-4.59 4.58-4.59-1.41-1.41-6 6 6 6z' fill='%23fff'/%3e%3cpath d='m0 0h24v24h-24z' fill='none'/%3e%3c/svg%3e[/img]
The 2021 Porsche 911 Turbo S is the most powerful 911 Turbo yet
Pro Racer's Take: 2020 Porsche Taycan Turbo S
Pro Racer's Take 2020 Porsche Macan Turbo
Pro Racer's Take: 2020 Porsche 911 Carrera S
2020 Porsche Cayman GT4 Pro Racers Take
Pro Racer's Take: 2019 Porsche GT3 RS
Pro Racer's Take 2018 Porsche 911 GT3 Touring
Pro Racer's Take: 2018 Porsche 911 GT3
Pro Racer's Take: 2018 Porsche 718 Cayman GTS
Pro Racer's Take: 2018 Porsche GT2 RS
Rare Metals: All the Porsches of Rennsport Reunion VI
2018 Audi TT RS vs. 2018 Porsche 718 Cayman GTS—Head 2 Head Episode 105
[img]data:image/svg+xml,%3csvg height='24' viewBox='0 0 24 24' width='24' xmlns='http://www.w3.org/2000/svg'%3e%3cpath d='m8.59 16.59 4.58-4.59-4.58-4.59 1.41-1.41 6 6-6 6z' fill='%23fff'/%3e%3cpath d='m0 0h24v24h-24z' fill='none'/%3e%3c/svg%3e[/img]
Cooling Flaps
The 911 Turbo S features adjustable cooling flaps in its left and right front corner intakes, which assist in regulating the amount of air that reaches the radiators. In most instances, the flaps stay closed at speeds between 43 and 93 mph in order to decrease drag (Porsche notes the Turbo S boasts a 0.33 coefficient of drag with closed flaps and its front spoiler and rear wing retracted). Place the car in its Sport, Sport Plus, or Wet driving modes, deactivate stability control, or raise the rear spoiler, though, and the flaps open up to keep the car's mechanical bits cool in anticipation of more dynamic driving.READ MORE
Sport plus is fully extended front and rear spoilers, you can manually retract them thru the screen
Keep in mind, if you just dont like the on-off feature, go into the menu system and edit ALL modes (sport, wet, normal, Sport plus) to NOT use this function (auto on/off). Then you dont have to mess with it again . It saves your settings. I was using the 'assignable button' to do the on-off disable, but when I realized I can permanently just set each mode to not use it, I just did that. No need for a tune, porsche allows for this 'disable' so you dont have to mess with it again.
The following 7 users liked this post by ILL_SMO_Q:
Billy Bluejay (02-10-2023),
Deerfield (11-16-2023),
mjf6175 (04-27-2022),
Ray Benson (04-27-2022),
and 2 others liked this post.
falls in to the same category as the volume button is the computer system reset (depressing the center of the volume control reboots the computer system)
Honestly, its a long read lol, but I am about half way done with the book. But thats where I learned about the setting each mode feature! Along with the 'swipe below the front porsche badge (slowly) across the front facia and the FRUNK will pop open' I used that one often, and again, no idea the car did that, until I read it in the book.
The following 6 users liked this post by hcvone:
992TX (05-21-2023),
Bluehighways (04-28-2022),
crazyrob (05-10-2022),
Onami (08-11-2024),
RD16RR (04-28-2022),
and 1 others liked this post.
I have a feeling that we may be dealing with some slight differences in PCM functionality either between models or build dates. Hopefully this will be rectified with some sort of software update. I have a 2022 Carrera S with what I am almost sure to be PCM 6 and there is no way to change the setting in each mode nor does the owners manual outline how to do this. Perhaps I am completely missing something, but for example in the GTS you can turn on/off auto blip in each mode but NOT in the Carrera S.
ILL,
perhaps you can describe the exact menu you are accessing to do this? My car only seems to allow modification of the “individual” mode but not the others as they resort to the default on each startup.
ILL,
The following 3 users liked this post by TrackJunke:
