Break In Period is Killing Me
#61
Received 5,402 Likes
Originally Posted by Kurac
And if I’m not mistaken, the German version of the owner’s manual doesn’t list this extensive break-in period.
#62
Who knows anyone who drove a new car of any kind in a spirited fashion from day one ignoring all these fear cultivating warnings and had a problem?
#63
This is exactly what I have done over decades with more new vehicles than I can really remember at this point and never had a problem.
Just as a general thing, let me put it this way. While this is nor Porsche, same applies. I was at Corso Pilota and was handed a Pista with 78 km on it. Porsche are not better, so why care when they don't,
#65
As painful as the 2,000 mile break-in is, I am following it based on the article below. I intend on keeping my car forever, so at least I can rest easy knowing I followed their guidance.
New Engine Break-in Conundrum
By: Ken Koop-The Yellowstone Region (Old Faithful Newsletter)Since I was a young boy, I have always wondered why it takes so long to break-in a new engine–especially those built by Porsche. Most people driving new cars also do not fully understand the real reason for the break-in period. Are you one of them? A good friend of mine just picked up his brand new 911 Turbo and complained about the break-in period taking so long (2,000 miles, not exceeding 4,000 RPM). We have talked about this issue many times over the past few years, always coming up with many scenarios of why such a long break-in period is required. However, we have never agreed on a reasonable answer. Well, you are about to find out the reason Porsche requires the break-in period it has today. The answer comes directly from the engineers at Porsche.
Before all of the parts are assembled for a particular engine; the pistons, connecting rods and valves are individually weighed and grouped together using similar weights to optimize performance. They are put onto a cart that moves along the assembly line with each engine block. This cart contains every part required to assemble that particular engine which includes each washer, nut, bolt, bearing etc… As a result, if any part is left in the cart at the end of the assembly line, then—Houston, we have a problem!At the end of the assembly line, the engine is filled with Mobil 1 Synthetic Oil. Each engine is then dry run (without fuel), pressure tested and checked for leaks. Every car coming off the production line is also run on a rolling road dyno. This enables all cars and engines to be tested at highway speed before they leave the factory. Some of the engines are also randomly selected to be tested on a dyno stand before they are installed into the car. The assembly plant has 5 dyno rooms located directly off the production line. The day I was on the tour, there were around 40 engines lined up on dollies. Some of these engines were in the process of being tested for quality control purposes. Once the engine is bolted onto the dyno, warm water is circulated throughout the engine to bring it up to temperature. The operator then starts the engine and checks for the correct pressures and temperature before the actual test begins. Engine speed is then increased in RPM steps to about 80% of its red line (the engine’s maximum RPM). The entire engine run takes around 30 minutes. Since each engine type (Turbo, GT3, Boxster or Carrera…) has a different red line, all of the data is recorded and analyzed after the test is completed.After the engine is turned off, the engine is again checked for seal leaks and its actual HP is compared to its advertised HP. To pass final inspection, the engine has to develop, at a minimum, 100% of what its advertised HP rating is. Also, the engine cannot produce more than 5% over that same advertised rating. If the engine falls out of those parameters, the engine is rejected and then torn down to determine why it did not deliver the anticipated HP.
When the test was completed, a Porsche engineer came over to review the results. I couldn’t resist asking the question that I had been searching to find an answer to for all these years. I asked “why does Porsche feel it is safe for a new engine to run at nearly full throttle in the factory, while the customer must keep the engine speed to no more than 4,000 RPM for a 2,000 mile break-in period?” I thought that was a logical question and if I do say so myself-well stated! The engineer replied, “Herr Koop, you do not understand (that I already knew). When we do our engine test, the metals inside the engine never reach the temperatures they would when driven on the street since the test session is fairly short. In other words, the bearings, pistons and cylinders never get a chance to thermally expand to their maximum. Therefore, there is little wear on the moving components. But when you drive a car on the street, the engine parts expand considerably more because of the heat being generated from the engine running for an extended period of time. No matter how tight the tolerances are, there is always a slight amount of expansion in the material. The moving parts can wear quickly if exposed to excessive heat and not always in a uniform way. We also constantly vary the speed and allow the engine to run at both high and low RPM’s”.
“Porsche wants the engine to break-in slowly, which means it needs to maintain a lower operating temperature (below 4,000 RPM) and to allow all parts to adjust (wear-in) within their own thermal expansion parameters. This is also the reason why Porsche wants the owner to vary the RPM throughout the break-in period; therefore the engine doesn’t get use to one operating temperature range”.
“Porsche has been using Mobil 1 Oil since the early 90’s. With its superior lubricating properties, it takes many miles of driving (without getting the engine too hot) before the components actually seat (or break-in). Porsche’s own tests reveal that after 2,000 miles have been driven, all of the moving parts have had a chance to wear into their adjacent surfaces and then an increase in engine RPM is permissible.” I replied, “JA DAS SOUNDS GUT, when you explain it that way, it makes a lot of sense.” I thought to myself “You Dummkopf, why didn’t you think of that”.
The engineer commented that there were many other moving parts other than the engine that needed break-in as well. Wheel bearings, constant velocity joints, tires, brakes and transmission were just some of the other components that were mentioned.
So breaking it down into layman’s terminology, it all comes down to; higher RPM equates to more heat, which leads to greater expansion. For a new engine, that can mean uneven wear on certain parts if excessive heat is allowed to build up. In Porsche’s opinion, the thermal expansion of different parts and various materials need time to adjust to one another. Porsche’s time frame for that to occur is calculated to be 2,000 miles, with the heat restriction being 4,000 RPM. So simple; who woulda thunk.
Many experienced Porsche engine builders and experts on the Flat-6 engine state that the peak power of a Porsche engine is developed around the 20,000 mile mark. This coincides with the principle of what the Porsche engineer was telling me; “Break it in correctly and the engine will last longer and perform better”.
It only took me 45 years to find out the real answer to this puzzling question. After I returned home, I explained this to my friend. As for our ongoing debate, we now feel a solution to this riddle has finally been reached. Neither one of us had the answer to this complex question totally figured out, but we were on the right path! I am finally able to resolve another one of my life’s unanswered mysteries and now it’s been crossed off the list. I hope this helps explain one of your unanswered questions in the car world as well.
- Post author:Yellowstone PCA
- Post published:March 24, 2011
- Post category:Porsche Tech
- Post comments:0 Comments
#66
This is also anecdotal. Some random dude dropping this dissertation like Plato's republic doesn't make it real.
rk-d (06-07-2022)
#67
I broke in a fully built motor in my Subaru STI in two days, no highways. I drove it up and down the length of the Delaware River from New Hope, PA to Port Jervis. I literally did it like laps. After the first day, we did an oil change at 500 miles and I continued. Proper aggressive break-in.
1000 miles in six weeks? 24 miles per day? You can do better than that in Arizona.
Heck, I did 900 miles in a single day in my 992C4S. (That was after break-in) It was not unusual for me to 200+ miles on a weekend day just adventuring.
Drive your car. Vary throttle and engine load. Have fun with it. Make a game out of it if you need to.
That's got to be at least twelve hours of driving. I've never done that in any vehicle, nor have I wanted to.
I've done several trips across the US in various vehicles and at my chosen pace it usually takes at least six days.
Getting to OP's question, I say just drive it. I don't know where you can really open up these cars anyway at least without attracting too much attention. (Ours is Guards Red).
We've got just about 2,600 miles and I don't think I've seen redline yet.
#68
Well, at some point, we have to believe or agree there is a source base of knowledge that can be respected or trusted. Otherwise, there will never be an answer. Just sayin’
Staffie Guy (06-07-2022)
#69
Why would the GT3 break-in be 900 miles @7,000 RPM if it had to do with heat related slow break in? Do turbos generate that much more combustion temps to justify double the break in period at 60% of the rpm’s? I believe the oil/water temps are around the same on the two when warm.
#70
Break ins are bogus.
My PECATL car had 750 miles on it. We launched it 7-8 times.
If break ins were that critical I’d imagine the factory sanctioned experience center would abide by the rules set forth.
#71
FWIW, nobody is having their mind changed on this subject here.
incoming992s (04-13-2023)
#72
Correct ... One of the prior posters had a copy of the Manual page it's 2000 mi or 3000km
BTW I also had a BMW N63 M550 and I broke it in gently and it never consumed oil.... one or two samples are not statistics.
#74
Well done for following prussian-precision instructions.
They are there for a reason, even though many people chose to ignore it when driving flat out on their private roads ;-)
#75
One thing for sure, the topic always brings spirited debate.
