Do I Need Winter Tires?
Old 01-10-2022, 11:30 AM
Mark S
Mark S's Avatar
Default Do I Need Winter Tires?
Below is typical winter weather where I live. I rarely leave the house before 10:00. We have about 10 days a year of more severe weather but will just leave car in garage those days. Do I need winter tires?
Old 01-10-2022, 11:52 AM
mksz51
mksz51's Avatar
No. You are fine. Avoid driving like a moron.
The following 3 users liked this post by mksz51:
dhirm5 (01-10-2022), Mark S (01-10-2022), Mike Murphy (01-10-2022)
Old 01-10-2022, 12:21 PM
manifold danger
manifold danger's Avatar
Received 1,139 Likes on 641 Posts
For sure no. I wish I lived where you do lol.
edit: agree with above post, as long as you're aware that it's cold and adjust your driving accordingly, I see no issues. I will also point out that cold + rain is even more alarming (cold is relative; really anything below 65 degrees and wet stay alert).
Definitely not justified with winter tires with that type of forecast though...
Some may suggest that driving below freezing temps can damage your tires, and that may scientifically be true. But to mine and many others experience, it isn't impactful enough to justify buying and switching to a whole different compound. If it does bother you, there are some very good performance all seasons you could use year round, and you'd be hard pressed to tell the difference vs summer tires even driven aggressively in warm weather. Sizes may be tough to find though.
My .02.
Tupper (01-10-2022)
Old 01-10-2022, 12:22 PM
Tupper
Tupper's Avatar
Received 1,610 Likes on 817 Posts
No. And drive it however you like as long as it's above 40 (45?) degrees
Below that, drive the Porsche the way it WAS NOT MEANT to be driven.....slowly and cautiously.
Mark S (01-10-2022)
Quadcammer
Quadcammer's Avatar
Received 1,394 Likes on 808 Posts
+1, you're fine without
Old 01-10-2022, 12:23 PM
breny4104
breny4104's Avatar
I would, especially if that lasts a couple of months. And if you like to travel to Colorado or NM to ski.
Old 01-10-2022, 12:26 PM
Mark S
Mark S's Avatar
Not a skier but I do plan on taking a Colorado road trip in the early summer.
Old 01-10-2022, 12:33 PM
AcousTech
AcousTech's Avatar
Hmmm. That might depend on what you run now, but I generally agree with the majority conclusion that in Prescott, AZ, you don't need them. Now, are you on Summer Tires currently, or All Seasons? Here's why I ask, Summer Tires, in particular, suffer from a "glass transition". Details here:
https://www.tirerack.com/tires/tiret...jsp?techid=273
Basically, at certain temperatures, the tire will rapidly loose their performance characteristics and become dangerous. If you're already on All Seasons, you're likely totally fine - even with the few cold days you'll have. However, if you're on Summer Tires the car could become really unwieldy on those colder days.
Mikster (01-11-2022)
Old 01-10-2022, 12:36 PM
Mark S
Mark S's Avatar
Brand new 911, so running summer tires currently. Too play it safe I can just use my SUV when it’s cold.
Old 01-10-2022, 12:50 PM
AcousTech
AcousTech's Avatar
Definitely a good idea. That link I supplied doesn't seem to work. Not sure why. Maybe try this one:
https://arstechnica.com/features/201...l-about-tires/
If All Seasons start to fail ~45 degrees, then Summer's probably fail at even higher temps. So the SUV seems the best route in colder temps.
Old 01-10-2022, 01:13 PM
Tupper
Tupper's Avatar
^ Huh? All seasons do not fail at 45 degrees. Please
And summer tires are fine in the 40s. I live in a proper cold weather region, so I know
Old 01-10-2022, 01:22 PM
AcousTech
AcousTech's Avatar
Your cars, your decisions. I was just trying to point out the technical factor that was worth being aware of if not previously known. Glass transition is real, but there can be debate about what temps it occurs at and on which models of tires. Lots of variables. Few absolutes.
Old 01-10-2022, 01:31 PM
Tupper
Tupper's Avatar
Yes, brand are different, but this is also not a "do what you feel, feel the flow" kind of thing.
All season tires don't fail at 45 degrees because you feel like saying that they do. They are called "All season tires" for a reason. I have All season tires on my BMW and have been driving in single digit F weather, no problem. Do you drive in single digit F weather?
Summer tires are the ones that fail at lower temps, NOT All seasons. Two different things.
russbert
russbert's Avatar
I live in East Tennessee and I do NOT use summer tires during the winter, why? Because I only drive on days when the temperature gets above 40 degrees which is almost always after lunch. If its close to 40 I drive very sensible, basically just driving it to keep battery charged, parts lubricated, etc. If it gets above 50 in the afternoons, I may have a little more fun but I definitely don't drive it like I do in the late Spring / Summer / early Fall.
You will develop a feel for it fairly quickly but your tires definitely effect your cornering and braking characteristics when it's that cold so drive sensibly and you will be just fine.
Old 01-10-2022, 01:50 PM
AcousTech
AcousTech's Avatar
@Tupper I'm really not trying to pick a fight here. I, personally, am not saying that "All All Season tires fail at 45 degrees". I do not believe that to be true, nor would I pretend to know enough to state where that transition happens with which particular tires or at which temperatures. I'm just trying to present the OP with information about the concept that different types of tires diminish their effectiveness at different temperatures. Not challenge or debate with you.
Quick Reply: Do I Need Winter Tires?
