Porsche 992 - BlackVue DR900X-2CH 4K UHD Dashcam Installation Tutorial
#46
I went with a more traditional install (former 12v installer) - The fuse taps look shoddy IMO.
At the top of the drivers fuse box there is 2 large plugs and a smaller one to the left. The middle one has a thin black wire which is 12v accessory, the far right one has a thick red/blue wire (35A) which is your 12v, ground is behind the dead pedal.
Actually the only complaint I have about the fuse taps is that I can't place the purple fuse "protectors" on with the fuse taps in place.
#48
Took this during install. Military splice. you could do this on passenger side, just need to identify the wires.
I can grab a picture of it cleaned up if you want.
mthreat (08-31-2023)
#49
Does anyone have settings that they could recommend?
I installed it a week ago, bur because of the hard suspension and driving style I get a lot of "event notifications" while driving.
I also get an event notification every time I open and close the door when it's in parking mode. I would like to keep some sensitivity and notifications while in parking mode so I know if something happens while I am away, but the alert every time I open and close the door will get old.
Any suggestions would be helpful. Thanks!
#50
#52
Fuse Box Carpet panel re-install
Hi,
Thank you for everyone's detail of write up, pictures and discussion. with this thread, i was able to successfully install my dashcam. However, I am having hard time putting back the carpeted panel for the fusebox.
Does anyone has any tips to putting this panel back together?
Thank you!!
Thank you!!
#53
Hi,
The following 3 users liked this post by mthreat:
