Blank toggles?
Old Feb 28, 2021 | 12:29 PM
Surge74's Avatar
Surge74
Default Blank toggles?
Does any 992 come with blank toggles?
In the example below, from a 992 Turbo Cab, what if you don’t get PDCC, does that toggle a become a blank/fake?
Old Feb 28, 2021 | 12:39 PM
HouTexCarreraS's Avatar
HouTexCarreraS
If you don't get PDCC, that toggle is still the normal/sport chassis switch.
Old Feb 28, 2021 | 01:05 PM
Russian Mafia's Avatar
Russian Mafia
It looks as though your toggle array may answer your question. Extra buttons become programmable (diamond symbol). My toggles are taken up by options. The only diamond I have is on the steering wheel.
Old Feb 28, 2021 | 02:36 PM
detansinn's Avatar
detansinn
No blanks in the 992. It either gets assigned to another feature or becomes programmable.
Old Feb 28, 2021 | 02:44 PM
siberian's Avatar
siberian
Any chance of programming a/one of them to disable ***? I know there's a workaround by starting in Sport mode, but I assume if you afterwards change it back to Normal it would re-enable *** right?
siberian
Old Feb 28, 2021 | 04:38 PM
detansinn's Avatar
detansinn
siberian
It’s a perfect button for the Home Screen.
Old Feb 28, 2021 | 08:18 PM
siberian's Avatar
siberian
You mean place the *** widget on the Home Screen and then use a diamond toggle?
siberian
Old Mar 1, 2021 | 03:24 PM
Bluehighways's Avatar
Bluehighways
I have the *** widget on the "Home" screen and I have the "Individual" mode programed to disable the *** function. I use the single diamond toggle switch on the dash to bring up my "Home" screen. I do wish Porsche had left the *** disable as a discrete mechanical switch as it was on the 997's. That way one can install a timer circuit that automatically toggles the circuit every time you start the car after a time period of your choosing.
Ex:
Amazon Amazon
Old Mar 1, 2021 | 07:42 PM
siberian's Avatar
siberian
Agree. I do NOT want (sensor or not) to determine if by -35F it's still OK to kill the engine at a stop so they can claim an extra 0.0003mpg. Definitely one of the first mods
siberian
