Wheel spacers? Yay or nay?
#31
Basic Sponsor
I got my spacers from ECS- great quality, decent price. I intended to go 10mm in the rear and 15mm in the front, but due to an order error (mine, not theirs) I ended up with four of each size. And the 10’s didn’t fit- wrong model. So the shop installed 15’s all around, and I’m happy with it for now but would not recommend 15’s for rears and will likely swap them out for 10’s or 12’s if I can find them.
We have 10mm and 12mm in stock ready to ship and they are guaranteed to fit your 992. We normally run a 15mm or 12mm Front and 10mm in the rear on the 992’s. Don’t hesitate to contact us with any questions.
Here are the direct links to our website.
10mm: https://4wheelspacers.com/shop/porsc...cers-bolt-kit/
12: https://4wheelspacers.com/shop/porsc...cers-bolt-kit/
4WheelSpacers Your #1 Source For The Best European Wheel Spacers and Adapters -SUMMER SALE ON LOTS OF PRODUCTS - QUALITY HUB CENTRIC WHEEL SPACER KITS FOR AUDI, BMW, MBZ, PORSCHE, VW 5MM UP TO 40MM !!!
EMAIL: INFO@4WHEELSPACERS.COM
WEBSITE: WWW.4WHEELSPACERS.COM
VarTheVar (05-23-2023)
#32
I have 8 and 15mm I pulled off my 992 when I sold it, they are from bbi if interested PM me
#33
I've got 10mm and 12mm never put on if interested from 4 wheel spacers. PM I'll make a heck of a deal :-)
#35
I installed Porsche 5 mm spacers on my 992 C2S with Sport PASM. There is no vibration at triple digits, tire wear is even, and there are no negative effects on the steering.
Modest spacers can be used successfully.
The following 3 users liked this post by Pete C:
#37
If you have spacers please post a picture of them from the side so we can see what is looks like close up
Kurac (09-03-2021)
#38
Also, these are very high quality but relatively cheap ebay spacers. I've had apacers on virtually all my cars and never had any issues. I've used expensive and cheap spacers. I've always bought hubcentric spacers and installed them carefully torquing to spec in a star patter. Ironically, the only time I had issues were with the pricier H&R spacers. One was milled improperly and was about 1.5mm narrower than the other. I have had no problems whatsoever with these spacers on my 992. No vibration at any speed, no worsening of steering feel or any issues. Also have RAS and no issues whatsoever when making full lock turns. No rubbing or anything.
+12mm rear spacers. Looks like rear tire tucking the fender here...
But this rear picture shows it's perfectly flush
another angle... doesn't look like it sticks out at all
rear fender looking from the front...
some may think the rear tire sticks out too far from this angle. I think it's totally fine.
Front w/ +15mm spacer (2021 front rim 20x8.5 +50). Looks like it pokes out slightly from this angle...
OMG! What are you doing? You're trashing your Porsche w/ crappy ebay spacers! It's sticking way past the front fender!
Uhh... not really. As you can see, depending on a very slight movement of camera angle, it looks like it's perfectly flush and not sticking out past the fender at all.
Another front angle view. I think this +15 spacer works perfectly even with the more aggressive 2021 stock +50 offset which already pushes the front tire out by 3mm more than the 2020 stock +53 offset.
The following 4 users liked this post by AlterZgo:
ateneo (03-05-2023),
Jeff Whitten (05-24-2023),
SoCal_Gentian992 (01-05-2022),
VarTheVar (03-16-2023)
#39
That looks really nice. Thanks for taking the time to post those pics. Also thanks for sharing the specs of the spacers. Your car looks nice....you look at it and you can tell it is slightly different from stock but can't put a finger on it. Spacers give you that ever so slight aggressive look.
#40
Found a few more pictures of the rear...
Looks like it sticks out a bit in the rear (again +12mm spacers)
This top down view of rear looks like it pokes out noticeably... but it really doesn't
It's all in the camera angle. This shows rear tire not poking out at all...
Looks pretty flush to me...
The following 5 users liked this post by AlterZgo:
babyghost (06-30-2022),
balucipher (10-01-2022),
tourenwagen (12-09-2021),
#41
I installed +15mm F and +12mm rear spacers on my car. My car has stock SPASM suspension and has the 2021 front rim which is a 20x8.5 +50 offset rim (pushed out 3mm more than the 2020 front rim). As you can see in the pictures below, depending on the angle of how one takes the picture, it can look like the tire is either flush or poking out a slight bit. I think +15F and +12R it's just about perfect for stock SPASM suspension. These sizes should also look good if the car is lowered, though you can probably go +18F and +15R for a more flush look if you are lowering the car. BTW, if you are worried about spacers causing tires to kick up a bunch of dirt on the doors and rear bumper, the first two pictures are unwashed after driving through a bunch of rain. Can hardly tell how dirty it is.
M3Inline6 (10-08-2021)
#42
#43
Front rim normal view… spacers not really noticeable unless you are really looking for them…
Close up of rear rim - due to concavity of rear rim, spacers are harder to see:
Front rim close up… spacer is obvious here at this angle peeking in between the rim spokes…
#44
Received 4,134 Likes
Spacers are great if you like to sandblast your lower quarter panel's paint job and the rocker panels..
#45
The following 2 users liked this post by M3Inline6:
AlterZgo (10-08-2021),
