Converting NA to EU Standards
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
Hi,
I thought I’ve seen a similar thread somewhere, but I couldn’t find it. Perhaps it’s in another forum.
I just shipped my C2S overseas, and I would like to convert it from North American to International/EU standards. Here are few items that I need to change. Please feel free to add or correct me.
1- Change rear turn signal headlights to Amber
Basically I need to buy Right and Left headlights. Probably a plug&play. I’m hoping this won’t require any programing.
2- Change side marker light from Amber to transparent
This is a Plug&Play. HOWEVER, I noticed that side markers in US/Canada (even transparent ones) will stay one all the time, and once the turn signal is turned on it will start flashing. In other countries, the side marker will stay off all the time, and will only turn on/flash when the turn signal is turned on. So I’m guessing this will require programing![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
3- Convert speedometer from miles to km and temperature from F to C
This could be done in PCM (I hope)
4- Update maps and system
I have no clue! Will the map of the new country be automatically downloaded or I need to purchase a new map for the new region (this is the case with many car manufacturers)
5-....?
5-....?
Given that the US spec taillight will light up the same bulbs for turn signal as well as braking, I wonder if that would in fact require coding. Not sure if the housing itself can differentiate.
Received 2,842 Likes
I'm sure it will require a new tail light, but not sure if the new tail light will require programming to work properly.
You can try asking the guys at GetPorscheParts or Suncoast - both US based, but might be able to find out for you. I know Suncoast is definitely aware of the amber vs. red physical difference, but I did not follow-up with them on how it actually functions.
KenTO (01-24-2023)
Are you moving for good or a short period of time? Is leasing a car there and putting yours in storage an option? Seems like a lot of expense unless you are staying.
You will also need to add particulate filters. US cars don’t come with them. If moving to EU, you might consider selling and ordering a car there.
Regarding this point, I read somewhere that it’s not a plug and play. The wirings need some modification. It might also need programing. Could anyone confirm?
Finally found this thread
I have imported a US 992, and trying to convert it to EU standards (mainly the red to amber turn signals). I bought EU tail light from Germany and installed the last night. Installation was as simple as plug and play, but it didn’t function as expected!
When I engage the turn signal BOTH the amber and red (break) light will blink.. what’s even worse is when I break BOTH amber and red will light up :”(
it's clear that the car is treating both break lights and signal lights as break lights. How do you think I can fix this!?
Thank you for following up on this post. I'm also looking to do an amber tail light conversion. The 991's required a tab to be shaved off on the tail light in order to fit, but now you're findings show the 992 US and Euro connectors are an exact fit!
I have also read that when these tail lights are changed, they need to be coded for "red" or "amber" else both colors will illuminate, someone with more coding experience on these cars would have to verify. Hopefully someone can chime in as I'm sure there are others who want amber rear signals on the 992..
Also, did you get someone to hit the brake for you to make sure both colors didn't illuminate when braking? I may order the Euro tails online and try experimenting with this as well if we can find someone who can code this properly.
Resurrecting this dead thread to see if anyone ever went through with this. I need to replace the entire rear assembly (all three components are badly scraped/scratched) and suncoast has the set for $1000, EU or US style. I quite like the amber rear turn signals but if it's not plug and play or reasonably close to it, I don't think I'm interested enough for the hassle.
