Battery Tender - UNSOLVED
Old 09-10-2020, 03:33 PM
markchristenson
markchristenson's Avatar
Originally Posted by kpblade
Just wondering, I've always used my cars as daily or almost daily drivers. The longest between starts was probably 3 weeks on my last BMW. To those that use battery tenders, what kind of time frames between drives do you feel the need for the battery tender?
I've wondered the same thing. On motorcycles I've often gone months without riding a particular bike, but with this car I can't imagine going more than a couple/three weeks.
Old 09-10-2020, 06:42 PM
JCH997
JCH997's Avatar
Per the Owner's Manual, ...
The battery will run down even if the vehicle is out of operation....To maintain its function, charge the battery approximately every 6 weeks or connect it to a trickle charger suitable for lithium batteries with a CC/CV or pure CV characteristic. Porsche recommends the charger and charge maintenance unit from Porsche Tequipment.
This appears in the section on lithium batteries which begins with...The 12-volt lithium battery is automatically disconnected from the vehicle electrical system if the battery charge is low.
Given the ominous "automatic disconnection" and the ambiguous "charge it every 6 weeks ...or connect it to a trickle charger" I just decided to put the car on a trickle charger when I garage it. I am driving it pretty frequently - once every two or three weeks - but I really want to avoid a hassle.
Old 09-10-2020, 07:13 PM
lucycan
lucycan's Avatar
On my more exotic vehicles I run a tender every time the car is not running. Some cars tend to do very odd things when the battery runs down even a little.
PBM (09-10-2020)
Old 09-11-2020, 12:13 AM
ipse dixit
ipse dixit's Avatar
Received 11,954 Likes on 5,212 Posts
A Porsche does not need to be on a tender if you drive it at least once every month.
Old 09-11-2020, 12:17 AM
Cheshi143
Cheshi143's Avatar
My wife's 991.2 cabriolet sits for at least three months at a time before she decides to drive it. Always starts up just fine.
Old 09-11-2020, 12:21 AM
aggie57
aggie57's Avatar
Received 2,903 Likes on 1,531 Posts
I used to travel weeks at a time and left my 997 at the airport. Fired up every time, even if it goes 'to sleep'. Only time it ever went dead was in the garage at work, I'd driven it to work that morning... Or the new one here 2 days after being delivered.
Old 09-11-2020, 10:50 PM
Pegg
Pegg's Avatar
Does the Porsche-charge-o-mat work with both lead acid and lithium batteries? If not, is there a CTEK product that does?
Old 09-12-2020, 12:58 AM
GT Rennsport
GT Rennsport's Avatar
Charge-o-mat does both.
https://content2.us.porsche.com/prod/pag/tequipment/Live/TequipmentInfoLive.nsf/0/F40A7027ADB08C82C1257FA4007C2CCC/$file/User%20Manual%20Charge-o-mat%20Pro_Manual%201%20EU.pdf
Old 09-13-2020, 01:11 PM
dasams
dasams's Avatar
This Porsche labeled charger is Li only and also 12V only.
Amazon Amazon
I purchased the similar CTEK unit that is Li only and has the connector. It's also half the price
Amazon Amazon
I also purchased the 12V plug so I can charge either way.
Amazon Amazon
Old 01-16-2021, 10:50 PM
deeare7
6th Gear
deeare7's Avatar
Originally Posted by JCH997
1. Turn off the ignition. (OK if charger is plugged into the house outlet and ready to go.)
2. Plug the charger into passenger side 12 volt outlet. (Make sure it is properly seated in the outlet. On several occasions I discovered it had not been. It's very awkward to set it in place. I find I can't do it from the driver's seat. I have to get out of the car, walk around to the passenger side, kneel on the floor - - praying position -- and then plug it in.)
3. Turn on the ignition. (Allow a couple seconds for the car's system to boot up. Click the mode button on the charger and make sure it is set to Li-Ion if the car has a Lithium Battery. The charger should show one of four levels of charge - from very low to full - which will gradually increase as the system registers and charges)
4. Turn off the ignition and lock the car.
5. After a couple hours, double check that it is still connected and charging (three lights glowing on the top of the charger) and go back to step #1 if it is not working.
My experience is that the charger does not reconnect to the car after a power failure, after the wall outlet powers off, or after the charger is unplugged from the garage outlet. Going back to step #1 seems to work.
I tried this procedure for 2021 992 and it did not work
Old 01-17-2021, 12:10 AM
RD16RR
RD16RR's Avatar
As suggested above, install a pigtail or direct connect with alligator clips in the frunk - simple to do, and easier than reaching in to the footwell
Old 01-17-2021, 12:52 AM
Bluehighways
Bluehighways's Avatar
Received 2,711 Likes on 1,277 Posts
My Battery Tender Wiring Solution:
Motorcycle Heated Gear Weatherproof Connection. Position chosen to line up with clearance in Hood Bracing.
Hard Wired to Battery with Quick SAE Disconnect.
Battery Tender Plugged In (Up Close).
Battery Tender Plugged in, Hood Open. FWIW the Hood can be closed all the way with the Battery Tender Wire routed as shown.
Old 01-17-2021, 01:01 AM
smiles11
smiles11's Avatar
Received 3,408 Likes on 1,490 Posts
Originally Posted by RxJedi
NOT ONE OWNER OF A 992 CAN GET THE TRICKLE CHARGER WORKING THROUGH THE INCAR PORT.
One owner can 😋
Originally Posted by smiles11
I plug into the passenger footwell 12v adapter while the car ignition is on, but engine is off; immediately following my last drive. Plug charger into outlet & press the mode button until it goes to Li-Ion. Go back & turn the ignition off. Lock the doors. Done.
Old 01-17-2021, 09:31 AM
JCH997
JCH997's Avatar
The 12 v plug on the charger has two metal clips. Inside the 12 v outlet there are also two metal clips; one at 3 and and the other at 9 o'clock. The clips have to be in contact with each other for the connection to work.
Old 01-17-2021, 10:13 AM
photonscience
photonscience's Avatar
One owner can 😋
I have a 2021 C2S - took delivery in December 2020. I have tried every trick suggested in this thread and others. Just tried Smiles11 procedure. No go.
I'm crying "uncle" on the 12v socket hook up and ordering the alligator clip adaptor to go directly to the battery.
Quick Reply: Battery Tender - UNSOLVED
