CarPlay Text Readout Audio Level Low
I have the Bose audio system, and while it can get plenty loud enough for music and voice broadcasts (more than enough to clearly hear speech), trying to listen to a text via CarPlay is next to impossible. There seem to be a few issues:
* It does not seem to play on all speakers (similar to navigation audio)
* Turning the volume all the way up as it’s playing back still barely cuts it
* It seems to reset, so by the time it starts playing, you can’t even turn it up to hear it
Does anyone else have this issue? Are there any tricks to fixing or is it another lovely PCM feature?
You'll need to go into the audio settings of your iPhone. The audio for text/Siri is separate from music your phone streams.
To adjust on your iPhone's text volume:
1. Tap "SETTINGS" app on your iPhone.
2. Scroll down and tap "SOUNDS & HAPTICS"
3. Under the "Ringers & Alerts" option, move the slider all the way to the right (Full Volume).
4. Make sure the "CHANGE WITH BUTTONS" toggle is turned OFF, so you don't accidentally change the settings the next time you handle your phone.
5. That's it.
5. That's it.
5. That's it.
5. That's it.
5. That's it.
5. That's it.
