Apple CarPlay - Thread & Questions
Still discovering some of the features and nuances between Apple CarPlay and Porsche PCM. Might be good to have a separate thread for all of the questions.
1). Homelink works within the PCM, however when I attempted to use Homelink from within CarPlay it does not work, even though you can select/add it’s widget to the screen within CarPlay? Any solution other than going back into the PCM and disconnecting from CarPlay?
2). After using the phone features or text message features of CarPlay it does not revert back to the music volume? I am having to manually select the music through the display or via voice command?
Is there an issue between Bluetooth and WiFi connectivity between the PCM and CarPlay that is causing some of these nuances?
I have totally given up on using CarPlay. Reason? When I get into my car in the garage, my phone is still connected to my home wifi, so the car won't connect. I'd have to drive some distance from my home, stop, and then reconnect my phone to the car's wifi to get it to show up as an option to connect. This is SERIOUSLY horrible user-interface and I have no idea who would find this useable (unless you don't have wifi at home that your phone connects to). Maybe I'm missing something big...
Many of the reviews commented on how fast the interface is...NOT!!! The lag when changing tracks on carplay is a second at least and I find the map in particular too slow, even after reducing the number of POI's displayed. If anyone has any tips to improve this it would be greatly appreciated.
