Clear side markers
#31
Assume these steps are for the driver's side marker (reverse left/right directions for the other side):
- Looking directly at the marker (helps to have dry hands for this) slide the marker to the right (towards the front wheel). It is a spring clip, so it will slide back if you let go (so don't let go).
- While the marker is slid to the right, push the right side of the marker away from you (towards the car) - the left side of the marker should be coming out rather easily at this point (you may have to grab it with your other hand and pull a little)
- Once the left side of the marker is free, the whole thing should come out rather easily.
- Using a flathead screwdriver, move up the clip securing the wire from the car to the marker.
- Attach wire & clip
- Put the right side of the marker in first
- Slide marker to the right (as in step 1 from removing it)
- Push left side in. If you're sliding the marker to the right, it shouldn't require too much force.
G650 (07-14-2020)
#33
@iliveoncaffiene your directions were spot on. Took me about a two minutes to replace them both. Thank you! Looks so much better than the US-spec amber lenses.
markchristenson (07-07-2020)
Todd C (07-13-2020)
The following 4 users liked this post by theostoubos:
#36
These look really good!
While I can see how the clear markers homogenize and 'clean up' the lighting arrangement very inexpensively and quickly, my only concern is the non-reflective quality of the clear markers. Specifically in an evening parking lot scenario where a 992 is parked (and vulnerable to those who don't park very well.) I always back into parking spots, so the passive amber reflective DOT-required lens becomes an effective line of defense at night when someone chooses the spot next to my car. The population is getting older, and as night vision deteriorates with age - I presume depth perception fades along with it!
audi4t (05-01-2022)
#40
Thanks to the instructions in this post, I can confirm this is a under 5 minute task. I swapped mine out as soon as I got home from the dealer. (Notably more difficult on the Macan)
Question - did anyone else notice that the passenger side light had significantly less slack in the wire/harness versus the drivers side? Needed to use a small tool to help detach the harness on the passenger side as I could not get the harness far enough out to use my fingers.
#41
Reviving an old thread here… but yday after a drive and some shopping, we arrived back at the car and the right clear side marker was popped out of the housing. Apparently, the clip that holds the side marker in had broken and it was just dangling. We had to use clear tape to temporarily hold it in place until we got home, so for now, I have one clear and one amber marker in the car. Pretty strange!
1BTD (09-02-2023)
car-fanatic (05-01-2022)
tourenwagen (09-03-2023)
