Brake dust
#61
Basic Sponsor
It sounds like you are pleased with the reduction in brake dust which is great (and expected). How are the pads performing in terms of bite/noise compared to your old stock pads?
-Rick
HINZ MOTORSPORT
Race Parts & Accessories for your PORSCHE
www.HinzMotorsport.com
Call: 414-212-5679
Email: rick@hinzmotorsport.com
-Rick
HINZ MOTORSPORT
Call: 414-212-5679
#62
noise - none
performance - a little bit reduced/less bite but its small difference and almost insignificant for street use, normal driving.
I have not gone on the track or some street racing. Just daily use and the occasional sporty corner taking, acceleration and sharp but not emergency style braking use.
So, for what I use the car for I take this every time as it simply makes my driving experience 100 times more pleasant knowing I don't need to look at those brown wheels again even after just one day use.
Patriot (12-22-2022)
#63
I've had the Hawk Ceramic brake pads on my 992 S for a week and about 90 miles of mainly non-highway (lots of braking) driving. I can confirm that these pads have significantly less dust than stock. Without exaggerating, I'd say they generate maybe 5-10% as much dust as stock pads. With stock pads, if I drove my car for 90 miles, the rims would definitely no longer look shiny - rears in particular. As for performance, they are fine for the street. Initially, they felt like they did not bite as hard as stock pads on regular application and required a bit more pedal pressure for the same amt of braking force. However, they stopped without issue when I tried some hard panic stops from about 70 mph. Now, after a week of driving, they feel normal - likely b/c I'm just used to them now... or maybe they did bed/break in more. They do not make any unusual squeaking noises or have any other negative issues that I can see.
I swiped my finger on both front and rear rims after 90 miles of driving and this is how little dust these pads generate. Pretty amazing IMO. You can barely see the dust on my fingers and the rims still look completely shiny like they were just washed:
Front rim:
Rear rim:
Front rim:
Rear rim:
The following 4 users liked this post by AlterZgo:
#64
Front rim:
Rear rim:
Front rim:
Rear rim:
#65
Received 4,067 Likes
TIA.
#66
Hawk. Part numbers are posted above. Why are these not available for the GTS? Is it cause the GTS acceleration vs S is so superior Hawk ceramics will not be able to produce legitimate stopping power? Muhahhaha
#67
GTS uses different brakes than GT4
#68
As noted by @westsiderkg
992 Carrera S/4S
The Front Hawk pad shape: HB848Z.646
The Rear Hawk pad shape: HB807Z.587
Of course, since you have a GTS, you will have to source 992 turbo pads as I think you have the same brakes as a turbo. You can also reach out to @KNSBrakes or Rick @Hinz Motorsport to see if they can source the right pads for your GTS.
992 Carrera S/4S
#69
Thanks. KNS helped be get my Carbotech pads, and it took multiple tries. I presume he'll be able to get the right Hawks now that we know what fits.
The GTS pads are a mix front and rear of other 911 pads.
