To PDCC or not
I am about to finalize the spec for my upcoming 992TT May production. So the configuration will lock up soon.
Since my TT will also serve track duty for 20-25 days per year, I was set on getting all of the go-fast goodies, which include S-PASM and PDCC.
However, having just read the Auto Motor und Sport Supertest of the 992TT-S, I am now questioning my choice of speccing PDDC. Here's the quote from the article (excuse the lame Google translate):
"Cause research, point 2: In the absolute limit range, the PDCC roll assistant filters out almost all Nordschleife bumps. It feels a bit like floating over the Nordschleife on a hovercraft. As a result, the feedback not only appears somewhat synthetic and slightly decoupled, but it also leads to unforeseen vehicle reactions. The Turbo S never really signals to its driver on the Nordschleife that the limit range has been reached. And once the limit has been reached, this 911 suddenly becomes sharp."
Any thoughts from other track junkies? Is PDCC the way to go or should I skip it?
Basic Sponsor
One of my reasons for ordering a Turbo instead of a Turbo S was the opportunity to order it without that option. The only reason the 991 and 992 has any hydraulics is for the sway bar end links. When ordered without that option the car is delivered with no hydraulics at all at that means the hydraulic pump, which is driven off the drive belt is now eliminated. To me, that's just a bonus.
You will not find any RS cars getting delivered with those options either.
To each their own. I know many people with have a very different opinion when it comes to this but I am happy to get a car without this option.
WORLD MOTORSPORTS
2170 W 190th Street Torrance, CA 90504
(310) 533-8900
- Akrapovic - BMC - TechArt - H&R - By Design - AMS - CSF - Kline - NGK - TiLugs - HRE - M Engineering - ID Injectors -
FULL SERVICE INSTALLATION FACILITY - STATE OF THE ART WIND TUNNEL DYNO - ECU TUNING
WORLD-MOTORSPORTS.COM
(310) 533-8900
CanAutM3 (03-02-2021)
Any thoughts on the track handling effects?
I went no PDCC...car handles like its on rails with SPASM anyways. Always love managing weight transfer on the track regardless of the seconds it may cost me not having a program do it for me.
All about the joy of the drive...
The following 3 users liked this post by Pad Bender:
Frank Abe (03-02-2021)
Basic Sponsor
I do have a lot of drag racing experience and our shop caters to that drag racing, 1/2 mile and street racing customer base. If you are purchasing your car for pure acceleration purposes than I would recommend going this route.
20-25 track days a year is a lot. I highly encourage you to 'keep your powder dry' and switch the allocation over to the GT3. It is purpose built for track usage and I think you will be much happier in the long run. Even for street usage the GT3 will be fine. I was very happy with my 991 doing about the same as you propose.
The following 2 users liked this post by redyps:
heshalosny (03-07-2021),
Tumbleweed (03-03-2021)
canaut -
Different driving experiences perhaps, but both equally good and enjoyable.
The following 2 users liked this post by ipse dixit:
alibo70 (03-07-2021),
canaut -
MaxLTV (03-02-2021)
According to AM&S, they feel that PDCC actually made them slower by making the car less predictable at the limit. And that's from a pro-driver. I found that quite interesting. I wonder if PDDC could also be (at least in part) the source of the criticism from Motortrend about driving the TT-S on track.
Also, with respect to PDCC specifically, I think part of the reason why GT cars do not have it (even as an option) is more for weight savings because I think at the end of day, one can simply adjust their driving styles to account for PDCC's behavior.
On these forums, considering the posts I've seen over the years from folks who track their car, I've most frequently seen NOT having PDCC and ceramic brakes as the reason(s) to get a TT over a TTS. I've never seen anyone on the GT3* forums wish that they could have specced PDCC (and though ceramics is a slight mix, it's generally not preferred either).
I wonder, if as AM&S noted, some of the issue they experienced with the TTS was due to the tires, or lack of true "sport tires".
"Cause research, point 1: You can perhaps compensate for the slightly slipping tire grip in Hockenheim with larger sideslip angles, but on the Nordschleife this will only succeed to a limited extent. In the Hockenheimer right bend in front of the Mercedes grandstand, for example, you stab relatively relaxed, because you have the asphalt run-off zone next to the piste in the back of your mind as an emergency solution. There are no emergency solutions on the Nordschleife, as the run-off zones are tiny. Slipping or smearing driving behavior robs you particularly of trust. On the Nordschleife, it helps the driver if the tire presents him with a reliable and precisely defined limit range.
The advantage of the PASM sports suspension, which is available as an option for the Turbo S for the first time, is counteracted by the lack of a designated sports tire. The sports suspension includes shorter springs with sportier spring rates and a different set-up for PDCC roll compensation. Lowering? Yes, by ten millimeters. Despite the sports suspension, the cornering speeds of the 992 Turbo S with Pirelli P Zero NA1 are, with a few exceptions, slower than those of the 991.2 Turbo S on Corsa tires."
Most definitely. The lack of optional R-comp tires for the 992TT/TT-S is their #1 case in point for their "slower than expected" 'ring lap time:
Agreed, it will be decent compromise since they are optimized for a 400lb lighter RWD car, so to optimal for the 992TT/TTS. It would have been preferable to have an optimized R-comp for the TT/TTS.
