992 GT3 and GT2RS Forum 2019-Current
Throttle response delay on 6MT
Old 10-06-2022, 06:37 PM
  #106
johnnylib68
johnnylib68's Avatar
not sure that is the reason in my opinion but I may try to release the clutch faster. I drive the same though so it should not be the reason. so today it got worse. not just a choking when downshifting from 3rd to 2nd, braking and then throttling back up. that did happen again today but it also just completely had ZERO throttle in second and then again downshifting to 1st. Zero throttle. Gotta take it in. Very odd. Only at a little over 3,000 miles.
  #107
jayely1
jayely1's Avatar
Any word on the sprint booster?? Month later and not a word..
Old 10-06-2022, 06:40 PM
  #108
johnnylib68
this is exactly what I get.
Old 10-07-2022, 09:05 AM
  #109
johnnylib68
​​​​​​I prefer not to use auto blip as well so it is a bit disheartening. I am taking mine to dealer for a diagnostic.
Old 10-07-2022, 12:56 PM
  #110
Dr. G
Dr. G's Avatar
Received 1,015 Likes on 518 Posts
I’ll let the OP chime in but he said it didn’t help with the specific problem.
Old 10-07-2022, 01:09 PM
  #111
3-Pedals
3-Pedals's Avatar
Received 1,572 Likes on 872 Posts
Maybe this was put in place to save the clutch/flywheel.
Old 10-07-2022, 02:33 PM
  #112
tareemaa
tareemaa's Avatar
Hey sorry guys, been MIA. So Dr. G was kind enough to send me the sprint booster, no improvement. At this point I’m thinking it is the no lift shift that’s causing this issue. The ecu doesn’t allow for a manual throttle blip unless the clutch is fully depressed and even then, it was to be a very and deliberate action. I owned several bmws and Porsches, mostly M and GT cars and have never had a hesitation like this with the throttle. I think the car thinks we’ll be shifting into the next gear and it’ll will be while the throttle pedal is being depressed for the no lift shift and so it’s not allowing the engine throttle to rise above where it needs to be. If you leave auto blip on, you should notice that the ecu is constantly intervening with the throttle to make up shifts and down shifts perfectly smooth. While it’s nice to have that perfect shift every time, I honestly don’t see this platform allowing for crisp heel toeing. If there is a way to code out the no lift shift, I’d be ready to try it.
Old 10-21-2022, 07:54 PM
  #113
3-Pedals
3-Pedals's Avatar
Is this the behavior in 991.2 GT3 as well?
Old 10-22-2022, 01:31 AM
  #114
johnr265
johnr265's Avatar
No.
Old 10-22-2022, 11:02 AM
  #115
3-Pedals
3-Pedals's Avatar
Is what’s on this video what you guys are talking about?
Watch it from 5:17
Old 10-24-2022, 01:44 AM
  #116
jayely1
jayely1's Avatar
Luckily I have not experiences this at all.. Just got mine 2 weeks ago.
Old 10-24-2022, 11:15 AM
  #117
Bill_76
Bill_76's Avatar
Same here, I had a 991.2 before and the 992 works the same for me.
GrantG (10-24-2022)
Old 11-16-2022, 03:12 AM
  #118
Chris C.
Chris C.'s Avatar
@tareemaa any update on this experience? My Touring may have a similar issue ... has Porsche duplicated it? Any Regional help from their experts?
Old 11-16-2022, 03:15 AM
  #119
jayely1
jayely1's Avatar
Just noticed it for the first time a couple weeks ago. It doesn't happen open and it always seems to be at a low RPM only under 20 MPH or so.
Old 11-16-2022, 12:27 PM
  #120
tareemaa
tareemaa's Avatar
Watch it from 5:17
https://youtu.be/hHBvcNUF-tk
yes, that is what has been happening. It creates a situation in which i preferred to drive it with auto blip on which does take away from the experience unfortunately. I would turn it off every time in drove the car to see if it was consistent, it is. The way the car and ecu is set up, I don't think it will allow a great heel toe experience.
Quick Reply: Throttle response delay on 6MT
