Rennline Exactfit Dash Phone Mount
#31
#32
#33
#36
Even if you have the wit to avoid texting and E-mailing while you drive, it's nice to have Waze running to supplement a radar detector. Between the two of them your chances of a ticket go down by about 90 percent.
I have my magnet glued to a cheap hard case that I modified to make it easy to fit and remove and I only use it in the car for this mount.
#37
#38
I put the metal piece between my phone and the case. Not glued. Just stuck it in there. I have a fairly thin case and just completed a 2k mile roadtrip and it did not slide around at all. And there was some hard cornering involved.
I also have a lightning cable right there, which connects my phone to the PCM as an iPOD player and I can play my full music library while the phone is being charged.
I can also use the aha service that way.
I am very happy with the setup!!
#40
I've taken my Renntech magnetic mount out now that I have a X.
{SOLD - or Given that is}
#43
That's where mine goes, if it's not in my pocket. It works much better as a phone holder than a drink holder.
#44
The X has a glass back, so the magnet won't attach to the phone directly. You'd have to add a steel stick-on plate or case, but those would interfere wireless charging. Also note that magnetic mounts interfere with the compass in the phone. This isn't too big a deal except that some nav apps get confused as to which way your car is facing when you aren't moving since they often initialize their orientation using the compass.
I frequently have a drink in my cupholder, so unfortunately this is not a viable option for me. . .but agree this is a great option.
#45
Have you found a replacement option yet? I have really enjoyed this mount, especially how it blends in due to it's low profile when my phone isn't mounted. I just upgraded to an iPhone X and will be switching to wireless charging soon, so I can't rely on the magnetic plate and need to find a new option. The only viable option I am seeing so far is something from ProClip, but those look awful when the phone isn't mounted. I've searched the other threads here, and haven't found anything better to move to at this time.
fxmixer (12-22-2020)
