New to me 2015 GTS - Tire Depth Question
Old 04-21-2017, 08:36 PM
jsimon777
jsimon777's Avatar
Default New to me 2015 GTS - Tire Depth Question
About to pick up a new to me CPO 2015 GTS Cab with 12k miles.
I need some quick advise on tires...
The rear tires are brand new!
The front tires passed CPO but are not new. I was told they have the following tread depth on both tires:
5.1 Inside
5.4 Middle
6.2 Outside
Im sure they are fine but since this is a new car to me...I'm considering putting on new front tires so I walk away with a car with 4 brand new tires.
Will be about ~$550
They are all Perrelli PZeror's
Any thoughts or advice?
Old 04-21-2017, 08:49 PM
Al.Fresco
Al.Fresco's Avatar
I believe they are 10/32 new (fronts) and 9/32 (rears) and should start pondering replacing by 3/32 or so depending on your driving habits (drive in frequent rain, etc) ... so yours are closer to gone than new. They are certainly still safe, so replacing is not currently needed, but is up to you if replacing them now adds peace of mind. Also keep in mind, 911's as a general rule will go through rears twice as fast as fronts so provided you don't always replace all 4, you'll be in this spot again at some point.
Congrats on your new to you GTS!!!
Old 04-21-2017, 09:00 PM
Bemo
Bemo's Avatar
Tires are cheap. You're in for so much fun, congratulations on a great car!!
Old 04-21-2017, 10:06 PM
StormRune
StormRune's Avatar
You might be able to talk the dealer into covering it if you point out this phrase in the Porsche CPO checklist (screenshot excerpt of the real checklist that they should go over with you). I doubt all four of your tires are now the same age as required here. You could ask to speak with Porsche corporate to double-check their approach if they don't agree and see if that moves them along. $550 is $550.
I like having matched tires too so I understand your dilemma. If they won't cover it and you decide not to I doubt you will have any problems unless you don't drive much and the fronts end up aging out (get hard) before the rears. I bet you can win this argument if you sounds like it is the only thing keeping you from being 100% satisfied. You can always say you checked on the forums and have learned that the fronts should have been replaced too. Dealers get a little scared of forum chatter about them.
Old 04-22-2017, 01:14 AM
jsimon777
jsimon777's Avatar
Thanks for the great information.
Sounds like the new fronts are the way to go plus a nice and perfect alignment.
I'm going to keep the fronts as back ups.
Here is the new GTS coming off the truck.
Old 04-22-2017, 06:24 AM
j997tt
j997tt's Avatar
Beautiful. Enjoy it.
Old 04-22-2017, 06:39 AM
tstafford
tstafford's Avatar
Received 1,085 Likes on 621 Posts
Enjoy the car for a few months and then slap some tires on it.
Old 04-22-2017, 08:03 AM
LexVan
LexVan's Avatar
Received 5,402 Likes on 2,513 Posts
Great looking 991.
12,000 miles on the front tires is nothing. Mine lasted 37,000 miles in 2.5 years. Spend the ~$550 on fuel.
If Porsche's paying, to make you and the CPO happy, let 'em.
Enjoy!
Old 04-22-2017, 01:08 PM
Larry Cable
Larry Cable's Avatar
Received 3,597 Likes on 2,340 Posts
spend the $14xx and put MPS4S'es on it all round
Old 04-22-2017, 07:16 PM
freeman
freeman's Avatar
I have my original P-Zeroes on. at >15000 miles. The rears are 4-6/32. The fronts are > than 7/32. I use 3/32 for my judgement. I took a 1000 mile trip last week. I am not sure MPS4S are correct for a Carrera GTS driven on the road. Nvertheless, I respect Dr. Cable's insight.
Old 04-22-2017, 07:21 PM
LexVan
LexVan's Avatar
Newest Michelin offering. Suppose to be an excellent tire.....surpassing the Pilot Super Sports.
Old 04-22-2017, 07:22 PM
rkwfxd
rkwfxd's Avatar
If you are just going to drive around on the street put some new meats on it. If you're going AX it and tack it to the track go burn down the current rubber some more before you replace it.
Old 04-22-2017, 07:57 PM
Larry Cable
+1 Super Sports were the best street tire out there, the 4S is simply an improvement (wet) on that ... distinct from the MPSC2's which are primarily
a track tire...
or maybe try the new Corsa's they optioned on the 991.2's that knocked several seconds off of its Ring lap time!
Quick Reply: New to me 2015 GTS - Tire Depth Question
