PCM Rebooting/Map Not Loading
#31
better give the dealership a heads up as they will have to special order the replacement head unit... they will probably re-flash the existing one, but if its the same underlying issue that will not fix the problem
#32
Hello all - "rebooting" this discussion, 2020 version.
Has anyone found a resolution other than full PCM head unit replacement?
- Software upgrades work?
My 2013 C2S is 6 months out of CPO (naturally) and just started the auto reboot feature every 2-5 minutes.
- Battery is def in need of replacement (new one in hand)
- I have an Iphone 11pro with latest software push
- PCM version is 3.43
- CD changer and maps work - most times it's tuning XM radio
- XM radio recently renewed but has been active for 4.5 years on this car
Thanks for any help here.
While I love my sports exhaust, I also dig rides with the right driving music, so...
#34
Thanks @shammerman made my way thru a couple but no resolutions posted. Will check this out! Time to re-do all my stations anyway
shammerman (05-26-2020)
#37
#38
#39
This may be a problem caused by a bad Sirius XM file pushed to Porsche's.
https://rennlist.com/forums/panamera...o-fault-2.html
#40
Anyone else try this fix with v3.43 software, did it work? I don't see the hard reset option- holding option button simply reboots to startup screen.
Curse on Sirius XM radio for this global blight!
#42
The PCM in my 2015 GTS started doing the reboot loop a couple of days ago, here are a couple of videos:
https://drive.google.com/open?id=197...6ScLCGsIpugVw9
https://drive.google.com/open?id=1am...ylikeorZOU6F8W
I contacted my dealership (sonnen), they said that there is an known issue with the PCM units, and Porsche are simply
replacing them when this occurs, when a video of the behavior is provided by the customer/dealer ... YMMV
Not sure if you can hear it on one of the videos but you can hear an audible 'click' from the PCM as it cycles, I suspect its either a relay or
the internal disk drive...
So it seems the only solution for this is likely a full PCM replacement, no? To keep costs down, the shop where I get my car worked on does race prep and as such has a ton of PCM 3.1 units sitting around from cars they’ve stripped out and converted for race use—I can source a replacement from them for cheap, however we don’t quite know what the procedure would be for coding (they do strictly mechanical work, not radios and such). Would this be something I’d have to take it into a dealership for, i.e. re-pairing the unit to the car? And would they be none too pleased that I’m bringing in a 3rd party replacement unit instead of buying it new through them? I'm just trying to figure out how best to navigate these waters.
Any info / experiences anyone might have on this would be greatly appreciated!
#43
I'm having this exact same issue on my 981, except I don't even get to the Porsche logo screen; mine just stays blank. The clicking sound is the optical head in the CD/DVD drive going through its boot procedures. I've pulled the fuse a couple times, leaving the car for a bit, then plugging it back in—this has worked a couple times, but once I turn the car off and back on again the PCM goes into an endless reboot.
#44
Chris C. (05-31-2020)
#45
